Manually cranking the car?
Old Apr 19, 2004 | 04:47 PM
WhiteKid's Avatar
I read a post on installing a new distributor and trying to get the timing back. I took my distributor out when I took the intake off. Having a hard time getting it back to where it was. How do you manually crank the car to get the crankshaft pulley mark lined up on '0' on the metal guage thing? Do I just keep turning the car till it gets there, or do I have to turn the crank pully?
Thanks alot guys.
Old Apr 19, 2004 | 05:00 PM
Stephen 87 IROC's Avatar
A couple of ways to do it. First of all make sure all the spark plugs are out. It makes cranking the engine by hand much easier.
The best way is with a flywheel turner but you need to be under the car to use it.
If all the plugs are out you can crank it over using a socket on the balancer bolt. only turn it so that it's tightening and make sure you don't tighten the bolt. You just want to turn it enough so that the engine cranks over. If you go past the timing marks you should go all the way around again twice. If you want to try backing up, you risk loosening the bolt off. If you do manage to back up, turn past where you want to be then tighten up to the mark.
Old Apr 19, 2004 | 06:40 PM
WhiteKid's Avatar
Thanks alot man. I was to excited to wait for an answer so I went out and saw the bolt. Turned it without taking out the spark plugs. That was a b*tch. Put the distributor back in and it fell inplace like it was supposed to be. Freind started the car and I adjusted it by ear and turning the distributor. Tapping everywhere....HAHA..... Took off the drivers side valve cover cause thats where most of the noise was and I found a wrench i left in there....No J/K.....3 Rocker arms were loose so I tightened them. Started it back up.....No noise at all on the drivers side....No more back firing either. .....Started to rain so Im gonna do the passengers side asap. Thanks alot guys for your help.
Old Apr 19, 2004 | 08:07 PM
92RS305#2's Avatar
dont you love it when you post a question on the boards and then find the answer yourself a few minutes later? i do it all the time
Old Apr 19, 2004 | 10:02 PM
WhiteKid's Avatar
Haha....well now next time someone has this question it will already be here for their reference.
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
USAirman93
Nov 24, 2014 03:37 PM
Queens94z28
Nov 20, 2014 06:03 PM
