New fuel injectors fixed several problems
Old May 3, 2004 | 12:33 AM
DanTheIROCMan's Avatar
Smile New fuel injectors fixed several problems
As some of you may recall, my 89 IROC had been suffering from the following hard to troubleshoot problems:
- Bad/rough/searching idle
- Running very rich/burning eyes just standing next to the car
- Excessive fuel pressure in tank
- slight miss at rpm
Well, seems that installing new injectors (nothing else was done) solved all of these problems. Go figure...
Old May 3, 2004 | 01:07 AM
aklim's Avatar
I can see 3 out of 4 problems solved by the new fuel injectors but I certainly cannot see how it solves the high fuel tank pressure.
Old May 3, 2004 | 01:23 PM
I know, me either.. But if you saw that other post where the guy just changed his spark plug wires, cap and rotor and the excessive pressure in the tank was fixed as well, then you know that this excessive pressure in the tank seems to be a very strange phenomenon with these cars. I'm just glad it's fixed though. Could it be that bad injectors cause the fuel to get excessively hot which then returns to the tank causing the other fuel to start getting really hot which leads to excessive pressure?
Old May 3, 2004 | 01:27 PM
aklim's Avatar
Unless it gets super hot, I would think that the gas that goes thru the return lines which are aluminum all the way to the tank would have cooled down quite a bit by the time it gets back. Just curious tho. Congrats.
AdsoYo
May 2, 2018 03:21 AM
Scottyboy
Feb 11, 2015 10:28 PM
Alex Barnes
Jan 24, 2015 10:21 PM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
