switching rearends
Old Apr 18, 2004 | 08:55 PM
bigpappab's Avatar
switching rearends
i have an 84 z28 that has drum brakes and im getting a rearend out of a 91 z28 the has posi and disc brakes. My question is, do i need to do anything to convert the rear ends?
thx for the help
Old Apr 18, 2004 | 09:13 PM
slayer6x6's Avatar
You should get a new prop. valve, but its not totally necessary. You should also get the lines from the disc rear. Other than that, it should bolt right in.
Old Apr 18, 2004 | 09:17 PM
92RS305#2's Avatar
how hard was it to find the Z28 rearend and how much did it cost you if you don't mind my asking. i was quoted 1100 for a posi upgrade and i'm trying to find cheaper solutions...
Old Apr 18, 2004 | 09:57 PM
transambill's Avatar
$1100 I'd take my chances on a complete used rear. There on e-bay all the time in the $200 -500 range.Or call a junkyard and if they don't have one they usually have a nationwide parts locater.
Old Apr 18, 2004 | 10:22 PM
krazzycowgirl's Avatar
My brother in law changed out his old 90 RS Drum brake system with my husbands 87 Disc brake system. Took him a day to do it. All he had to do was make sure he changed the E brake cable.
Old Apr 19, 2004 | 08:00 PM
92RS305#2's Avatar
yea 1100 bucks! 800 for parts and 300 for labor. so i should just search ebay for a posi rear end from a late model 3rd gen? but will i still be able to put 3.73 gears into a stock posi rear w/o spending alot of cash?
Old Apr 19, 2004 | 09:16 PM
slayer6x6's Avatar
I got my 9 bolt for 70 bucks from a guy around the corner from me. The only thing it needed was pads, and rebuild the calipers. Those rear calipers are pretty tricky to rebuild though.
Old Apr 20, 2004 | 07:40 PM
LiquidSkies's Avatar
im getting ready to swap out my drum rear also. i have a BW 9 bolt 3.27 posi disc rear i got for nothing. im currently waiting on the PBR backing plates and caliper cradles. for the swap i know you will need the E brake cables and the lines for the calipers. i've heard of people flairing the lines and running new lines of the stockers. you will need a prop valve if you have drums and are using the stock dic setup. thats one reason why im going PBR... can reuse my old prop valve. other then that, the rear bolts right in. 4th gen rears are a direct bolt on also. i would go wit ha BW rear though, they are stronger then a stock 10 bolt andyou maintain your stock backspacing on your rear wheels. unlike the 4thgen rear swap since its 4inchs longer then the 3rd gens
Old Apr 21, 2004 | 11:50 AM
MrDude_1's Avatar
first time i did it, it took 3 hours.. i have it down to 2 1/2 now.
its pretty easy... everything unbolts, the new one bolts in.
as long as the brake line from the axle has the same fitting as the hard line on the chassis, you're fine... i know 89 to 02 are the same, but i dont know when they changed it to the new one.. i read that it was in 83, but im not sure.
you need the parking brake cables if going from drum to disc.
its a bolt in thing though. hardest part is balancing it on the jack to get the bolts started, and bleeding the brakes when you're done... and thats not too hard.
Old Apr 21, 2004 | 06:26 PM
question, when converting from the regular iron calipers on the 9 bolts to the PBR setup, what year E brake cables are needed to adapt to the PBR calipers? i havent bought any calipers yet so i figured id ask what year car to get the E brake cables and calipers/rotors from. ill be buying them new from NAPA or someplace problebly, unless someone knows a good place to get them online.
Old Apr 21, 2004 | 08:42 PM
You'll need cables for a 89 9 bolt. 1989 was the only year that had the PBR brakes. I'm about to do the same swap myself.
Old Apr 21, 2004 | 09:16 PM
awesome. should i get the calipers and rotors from that year? or a later year? im thinking of getting the latest year, i know sometimes they perfect a piece as the years go on. like the heavier built 700r4s in 89+ fbodies... or the WC T-5 in 88+
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
