Really Need Help Fast On A Ramjet!!!
Old Apr 28, 2004 | 01:49 PM
REALFAST95Z28's Avatar
k im postin this for a friend, hes got a 82 camaro with a ramjet 350 in it.. he is havin MAJOR problems.. the car will not start or will die.. when the TPS sensor is plugged in the car will not start whatsoever.. notta... with it unplugged the car will start but if you even touch the gas whatsoever the car immediatly shuts off.. no sputter no nothin, immediate shutdown??? we need help FAST!!!
also NO error codes at all... new fuel filter, fuel pump, knock sensor, and TPS sensor
Old Apr 28, 2004 | 02:16 PM
kandied91z's Avatar
put a new sensor in...if it ran before and now it doesn't and it shows that the sensor is bad it would be a good way to go. most places can test them for you.
Old Apr 28, 2004 | 02:19 PM
we already replaced it.... still no worky...
Old Apr 28, 2004 | 04:00 PM
kandied91z's Avatar
are you sure its good, plenty of them seem to be bad out of the box.
so the motor worked for ahwile with no problems and now your having this problem or is this a motor swap that isn't working from the start?
Old Apr 28, 2004 | 04:55 PM
motor has been runnin awesome for 2 years... now all of a sudden it just turned off.
Old Apr 28, 2004 | 05:03 PM
kandied91z's Avatar
well if the tps is off you need to have it checked anyhow since it isn't working properly. wish i knew more but someone will chime in soon. if you are in a hurry try over at thirdgen.org too.
Novo
Jun 14, 2016 02:58 AM
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
