accel header plugs
Old Apr 12, 2004 | 05:30 PM
fullcollapse's Avatar
accel header plugs
does anyone make short header plugs besides accel.. i cant seem to find any anywhere even on the internet which is odd.. i cant stand these accel's they are fouling out once every two weeks pulling them out scrubbin them down.. maybe a tuning would be alright lol..
corey
Old Apr 12, 2004 | 09:25 PM
aklim's Avatar
I don't think so. Can you go one heat range hotter?
Old Apr 12, 2004 | 09:34 PM
Chris`s85Z28's Avatar
Man I LOVE my Accel shorty plugs they`ve been in my Z28 for 2 years and I only need to change them now and my Car is running rich as hell
and I don`t think anyone else makes shorty plugs
Old Apr 12, 2004 | 09:38 PM
sounds like some more of my good luck... my 288rwhp dyno with all thats in the sig below lol... i think i just need a new damn car lol
corey
Old Apr 12, 2004 | 09:49 PM
Sitting Bull's Avatar
Re: accel header plugs
corey
Hey full,
Bosch Platinums, the single prongs, are very short and should last 3 or 4 times longer than your Accels. I have used the same set on my car with headers for 3 years and have no clearance or fouling problems. The only time you should not use platinums is if you are running nitrous, since they will cause a chemical reaction that leads to fouled plugs, too.
It does sound like you are running rich, though. A tune up of the fuel and ignition system sounds like it is in order
Old Apr 12, 2004 | 10:18 PM
thanks ill look into getting some of these..
corey
Old Apr 13, 2004 | 12:31 AM
TheGreatJ's Avatar
I use the regular single-strap Bosch's too. Never had a problem with them, and I've been running the same set for almost 3 years.
There's not a plug in the world that will stand up to excess fuel though.
Old Apr 13, 2004 | 01:35 AM
WhiteKid's Avatar
Re: Re: accel header plugs
Originally posted by Sitting Bull
Hey full,
I dont recommend Bosch Platinums. So many people come in with V8's and tell me how much they suck. I use regular AC Delco's. Bosch Platinums are bad news.
Old Apr 13, 2004 | 01:41 AM
Re: Re: Re: accel header plugs
When you've run the Platinums come and tell me about it. Until then you're just another yap from those who don't know.
Old Apr 13, 2004 | 01:42 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
I never had a problem with my accels fouling out. I jsut hate that the tip screws off of them. Ive had the tips unscrew on me, and then lost the tip int eh engine bay or on the ground
If you go to regualr length plugs I recomend NGKs
Old Apr 13, 2004 | 12:06 PM
aklim's Avatar
I think you are going to have to putz around till you get it right. NGKs have worked for me. I wouldn't use Bosch Plats simply because I want to see what the engine is doing on a yearly basis and not leave it in for a long time. Also they are not good for turbo applications.
Old Apr 13, 2004 | 01:38 PM
So? Take the plugs out once a year to look at them, if that is what you desire
Old Apr 13, 2004 | 08:26 PM
aklim's Avatar
I know but when the plug will last for 100K, it is harder to get the motivation to take it out every year. I took my plugs out of my truck when it hit 50K and not before. This way it forces me to do it because I have to.
I have run Bosch Plats and even +4 but never noticed any difference in the starting or idling and it does the same as far as having the tan color. I have tried the AC Delco Rapidfires and not noticed any real difference so I choose not to spend big bucks on a plug. Rather, I replace them annually because I have to.
Old Apr 14, 2004 | 11:54 AM
Hey full,
I HATE bosch they are the worst plug i`ve EVER used. I put them in my 89 2.8L celebrity and they were great at 1st two months later they where crap so I switch over to A/C delcos and they were WAY cheaper and WAY better then the Bosch platinums. The guy that I bought my S-10 off of said he had the Bosches in the 2.8L in the truck, I don`t know since I`ve never check. But the truck runs like CRAP. I`ll never put my 305 though those plugs they are a horrible plugs.
I run A/C Delco and Accel those are the best plugs to me. But I do hate when the tips on the Accels come lose.
Old Apr 14, 2004 | 12:49 PM
dj haf's Avatar
not trying to jack the thread... sorry, but i was curious... im running 10:5 to 1 compression with iron heads and 93 octane... i can get higher if i wanted to though. my question is, what heat range should i go with if i decided to go with the NGK plugs?
