radiator
Old Apr 28, 2004 | 04:36 PM
tohigh4you's Avatar
radiator
Ok guys,
I am looking for direct replacement radiator that will cool 600+HP. My biggest problem is Im very limited on depth because my blower pulley is VERY close to the upper radiator as it is. Any ideas??
Old Apr 28, 2004 | 06:59 PM
TheGreatJ's Avatar
BeCool makes a bolt-in replacement that should be adequate, although I'd call them to verify that it'll handle the heat before I ordered it. If it's not enough, you can yank the A/C condensor and gain an extra inch in the front for a thicker core.
Old Apr 29, 2004 | 10:46 AM
tohigh4you's Avatar
Car currently has no ac so that should make it a little easier. Also, I have seen summit advertise a generic alum radiator. Has anyone tried one of these in our 3rd gens. Also, what about relocating the upper rad hose for more blower clearance. Thanks!
Old Apr 30, 2004 | 09:23 PM
1984camaroz28's Avatar
im in the same boat . the one in summit is 500$
Old May 1, 2004 | 07:15 PM
Marc 85Z28's Avatar
Do a search over on www.thirdgen.org Someone will a setup similar to yours (in power output) installed a much more cost friendly Griffin universal into his car. It required some fabrication, but he claimed the results were worth it.
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
68camaroboltz
Oct 5, 2015 01:46 PM
Pwilson59
Sep 3, 2015 08:47 PM
