V6 to V8 Question
Old May 1, 2004 | 12:30 PM
TNchic's Avatar
V6 to V8 Question
1991 Camaro RS w/ 191 V6 and auto tranny
Can the 191 be replaced with a 305 or 350 or will the tranny also have to be changed?
Granted I'll prolly be changing the tranny over to a manual, but Id like to wait and do that later and do the engine first if possible?
any suggestions?
Edit: Im looking for the question too, but thought Id ask here and maybe get pointed in the right direction???
Old May 1, 2004 | 05:47 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Im pretty sure you have to replace the tranny.
Old May 2, 2004 | 02:22 PM
Tim89Rs's Avatar
IF the car has a 700R4 trans in it, you should be alright. Just make sure when you put a 350 in there that you should rebuild the trans and change your stall convertor and get some gears in the rear .
Good luck with it
Tim89Rs
Old May 2, 2004 | 03:21 PM
PyRo9862's Avatar
The manual tranns are differant the 700R4's are similar enough that it should work. Don't be suprised if it doesn't like the newfound torque though. I would plan on spending the money on replacing the tranny, so if you have to your not screwed, and if you don't you have some money to throw somewhere else.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
