info on superchargin a 350
Old Apr 22, 2004 | 11:57 PM
WhiteLightnin83's Avatar
Question info on superchargin a 350
ive been thinkin about puttin a supercharger on my 350 small block, first of all can i just put the supercharger on the motor without having to do anything to it(in terms of having to rebuild some of it), if not, what do i gotta do? i'd also like to put an enderle style hood scoop on the supercharger so how big of a supercharger can i go with and still be able to drive it around to school and all to show it off, i want a sweet lookin car with lots of power, but still keep it highway driveable and i don't wanna have to do a whole lot to the motor to put the supercharger on it. how much money am i lookin at for everything its gonna take to have this set up? thanks
Dustin
Old Apr 26, 2004 | 12:34 AM
nobody in this forum runs a 6-71 or 8-71 blower or anything on their cars that they could explain to me? not many cars built up for the strip anymore i guess....
Old Apr 26, 2004 | 12:57 AM
Ville H. Valo's Avatar
how old are you, do you have an i dea on how much a supercharger costs? if you supercharge your engine i would suggest a rebuilt and maybe some aftermarket fuel injectors. and with reguards to the hood, what are you talking about, are you asking if a supercharger would fit under the hood, if so, most superchargers made for our cars fit under the stock hood.
Check out
http://www.vortechsuperchargers.com/
http://www.procharger.com/
i would suggest procharger, they keep the engine colder.
Old Apr 26, 2004 | 02:16 AM
aklim's Avatar
You might have to drop your compression to 8:1 to run a charger with great boost. How much power do you plan to make? depending on your answer, you might have to really make some mods to the block so it will hold up.
Old Apr 26, 2004 | 03:01 AM
Error404's Avatar
Honestly, for the cost of a super charger, I would build up the engine with no forced induction, then later put the supercharger on. You'll get alot more power that way if you build the engine up (especialy if you have the cam and compression right for forced induction)
Old Apr 26, 2004 | 06:16 AM
aklim's Avatar
I would think the SC cams are different from the NA cams. If you are going to do that, maybe you should put in a cover for the camshaft that is in 2 pieces so you can take it out without having to disturb the oil pan.
Old Apr 26, 2004 | 10:42 AM
aklim's Avatar
With a turbo you'd have to plumb an intercooler in and our cars are not that spacious.
Rittmeister
Aug 7, 2015 01:13 AM
Henson071
Aug 4, 2015 09:32 AM
Collinjacobfowl
Jul 30, 2015 09:35 PM
colts0455
Jul 20, 2015 09:52 AM
1995Blackz28
Jul 20, 2015 09:34 AM
