700R4 question
Old May 3, 2004 | 03:02 PM
V8Rumble's Avatar
Question 700R4 question
I'm feeling kind of dumb for not remembering this, especially since it's been right on the "tip of my brain" for the last several days, but what the hell..
What part is the most likely culprit when your 700R4 hangs in one gear too long when you're at WOT? I seem to recall that it's a valve of some sort, & it's not too expensive or difficult to replace...
And I know that when someone tells me what it is, I'm going to get all pi$$ed at myself for not remembering...
Old May 3, 2004 | 03:30 PM
klumb15's Avatar
i dunno what its called, but i know my car does that too, and thats not very good if you got TPI, cause my car revs up to almost 6 grand at WOT before it shifts, and TPI falls flat on its face between 4500 and 5000...
Old May 3, 2004 | 03:45 PM
92RS305#2's Avatar
i think your car just needs more power
Old May 3, 2004 | 05:20 PM
IROC-T's Avatar
Think of Television , TV (throttle valve)
Old May 3, 2004 | 08:30 PM
92RS305#2's Avatar
i was just joking above, my car likes to hang in second gear too long too. would a shift kit help aside from rebuilding the tranny all together?
Old May 3, 2004 | 10:35 PM
V8Rumble's Avatar
Smile
Arrrrghh, that's right!! (Dammit!)
Thanks for the nudge to my brain cells, IROC-T!
No doubt, no doubt, but it (and I) are both suffering from a bit of "lack-o-fundage-itis"!!
Thanks again for the answers, guys - you rock!
Old May 3, 2004 | 10:42 PM
V8Rumble's Avatar
If I were you, I'd start with the TV valve & see if it fixes it. You can always spend more later!
Also, my understanding is that a shift kit is a great idea - as long as your tranny's in pretty good shape to begin with! If it's not, then it could aggravate the existing problem(s).
Basically, what a shift kit does is to make the bands & clutches engage more quickly, thus lessening the "rubbing" that they do as they're engaging. Most people like a tranny that shifts so smoothly that they barely feel it, me, I cringe.
That's the way I understand it, if I'm mistaken, I'm sure someone will let us know...
Old May 3, 2004 | 11:23 PM
FruityOne's Avatar
The TransGO shift kits will actually improve the life expectancy and power handling of a stock 700r4 too. Not as much as a nice heavy duty rebuild, but good enough for what you pay.
Its likely the TV cable is out of adjustment. If not then the Throttle Valve inside the pan may be sticking.
Old May 4, 2004 | 01:06 AM
aklim's Avatar
When my tranny did that, it was going south. Drop the pan and see if it has metal pieces in it. See if you have enough fluid and if the quality is good. Change filter if you drop the pan.
Old May 4, 2004 | 12:11 PM
ARTIC_Z's Avatar
I have a 92 305. and it stated doing that, then i noticed it was low on fulid. so i just did a service. i get under there i look at the pan oil everywhere. WTF? so i pull the pan oil was black it was just serviced 7000 before i did this. there was alot of metal in the pan and on the magnit. 1 week later it blew up. so i had it rebuilt $800. and that was changing it my self. but i got a shift kit better clutch packvet servo. ran real good after that. mine had 179,000 miles tho. he said it had nver been rebuilt. and he was amazed he said 700's go bad every 100,000 or so depending on driving.
My 94 z did the same thing twice in three months.
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
GA93FORMULA
Jul 24, 2002 11:38 PM
