none of my guages work...
Old Apr 24, 2004 | 05:04 PM
Teknohund's Avatar
no guages work....
Ok, first of all I go out to start the car this morning. Smoke starts coming from behind the dash. Shut it off, find out its the aftermarked temp guage ground wire. It got so hot it melted the insulation. I have had this guage for over a year no problems. So I take it off, and it was sparking when it touched some metal I wasnt careful with. Also for some reason when I hit the brake pedal, my radio and autometer tach stopped working, but started again when I let off the brake. Then everything went dead. No tach, radio, intrument cluster, electric radiator fans, even the back hatch motor. But it still starts and runs. Any ideas???
Chris
I was thinking a fusable link somewhere to the fuse box, but i dont remember where to look. its been a long day.
Old Apr 24, 2004 | 07:47 PM
aklim's Avatar
Could it be a bad ground instead?
Old Apr 24, 2004 | 09:17 PM
tom2's Avatar
Sounds like you lost a ground, grounding through the brake lights. Start by checking fuses for the lights and gauges. Then figure out where you lost the ground.
Old Apr 24, 2004 | 09:40 PM
Teknohund's Avatar
it would have to be a ground to the fuse box if I did. No power at all coming from it. Where is the ground for the fuse box, if there is one...
IndyZman
Oct 22, 2015 02:17 PM
dylan1303
Aug 12, 2015 02:00 AM
alphaauto
Jul 26, 2015 04:40 PM
2QUIK6
Jul 2, 2015 07:02 AM
Ucantcme57
Jun 15, 2002 01:46 AM
