Trouble Codes
Old Apr 29, 2004 | 04:32 PM
klumb15's Avatar
Trouble Codes
where can i go to decode these codes...i got a 33 and a 36...i think the 33 is a map sensor, but i'm not sure...does anybody know off the top of their head what these codes are, and if not where can i find out....i also got a 12, but i think that just means its running normal or something, thats what a buddy of mine told me...
Old Apr 29, 2004 | 04:37 PM
Marc 85Z28's Avatar
12 is normal, and means the ECM is running properly.
33 is for your Mass Air Flow sensor.
36 is for your Mass Air Flow sensor burnoff circuit.
Check your MAF sensor for contamination and MAF burnoff relay for proper operation.
Old Apr 29, 2004 | 05:59 PM
krazzycowgirl's Avatar
http://www.hpiv.net/diag.html
Old Apr 29, 2004 | 06:11 PM
klumb15's Avatar
whats an igniton system circuit error(#36) and how do i fix that? and thanks for the whole list of codes, that'll help me alot...i greatly appreciate it...
Old Apr 29, 2004 | 08:45 PM
Marc 85Z28's Avatar
Noooo... There is nothing wrong with the ignition. Code 33 is for a high voltage condition at the MAF, and code 36 is a MAF burnoff circuit failure.
That above link is crap. Although most of GMs DTCs are generic, they do have certain codes that are vehicle/engine specific - both of these being vehicle specific.
Need diagnostic help? Here's a GOOD link:
http://www.thirdgen.org/techbb2/show...de+maf+trouble
Old Apr 29, 2004 | 08:55 PM
klumb15's Avatar
ok....how do i fix it?
Old Apr 29, 2004 | 09:20 PM
That is out of the engine code Manual from chiltons. Yes its Generic. thats why there are two of them. & its for Camaros if I remember right. My husband did that up when we started having problems with my car.
Old Apr 29, 2004 | 09:46 PM
TheGreatJ's Avatar
As a professional mechanic I can tell you that Chilton's information is pretty worthless. In fact, it's almost as worthless as Hayne's information. I'd take a good voltmeter over either one of them any day.
Old Apr 29, 2004 | 09:56 PM
But for those who cant afford a Pro Mechanic they work in a pinch. They are better then someone who dont know what they are doing & messing up your car.
Old Apr 30, 2004 | 12:11 PM
Marc 85Z28's Avatar
DP
Marc 85Z28's Avatar
Yeah, but when they lead you in the wrong direction they do more harm than good. That code 36 is an excellent example of that. I'll secondwhat TheGreatJ stated, as I'm a Ford and ASE certified technician, and I do this stuff on a daily basis.
Nowadays, Chiltons is crap. ALLDATA is a much better source.
klumb15: Did you follow my link? The MAF burnoff relay is notorious for sticking. 90% of the time a replacement is in order. As far as the MAF, carefully cleaning it out with carb cleaner sometimes does the trick. Make sure its dry before plugging back in.
Old Apr 30, 2004 | 03:41 PM
klumb15's Avatar
alright......do you have a ballpark figure on the cost of a MAP burnoff relay and a MAP sensor? and thanks for the help marc, all your knowledge is greatly appreciated
Old Apr 30, 2004 | 05:17 PM
do a search for Chiltons & it comes up with 46 threads
Old May 1, 2004 | 08:16 AM
Marc 85Z28's Avatar
No, not MAP, MAF. If you go looking for a Manifold Absolute Pressure sensor you're goin to create a big headache. You need the Mass Air Flow, MAF sensor and relay.
The relay you can pick up just about any parts store, and its not expensive. Probably less than $10.
The MAF however is bit more. Probably several hundred dollars. I still say you should attempt to clean it first, and here's why:
When the MAF burnoff relay fails, so does it's circuit function. The burnoff relay does just what it implies, it provides a voltage source to the MAF element after shutoff, to "burnoff" any accumulated debris on the the sensor that could cause a malfunction.
Clean it first. If that does not fix it, you'd be best advised to either:
a) find a friend with a TPI car and do a quick swap, or
b) get a DVOM (Digital Volt Ohm Meter) and check the MAF sensor output yourself. Its actually pretty easy.
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
