Couple questions for the experts...
Old Apr 23, 2004 | 08:53 AM
91BigRedz28's Avatar
Question Couple questions for the experts...
I swapped a motor last summer...a 305 TBI from a '93 Caprice and dropped it into my Camaro, which is TPI. Obviously I put the TPI on the engine. I've read that the TPI and TBI heads are different, but how much? Anything else I should know? The car runs great, if that helps your investigation.
Also....I've got about $300 to throw around, the car is stock...what's a good starting point?
Thanks a million
Old Apr 23, 2004 | 08:57 AM
Forgot to mention....
My speedo doesn't seem to work for the first 15 minutes (pretty consistent time)...but after fifteen minutes it springs to life and works fine for the rest of the voyage....is this something easily fixable? Trans. is auto.
Old Apr 23, 2004 | 12:50 PM
aklim's Avatar
Check the connection for the VSS in the tranny. That could be bad or maybe it is the VSS itself. Mine did that till I changed it.
Old Apr 23, 2004 | 03:25 PM
Rice Killer87's Avatar
Re: Couple questions for the experts...
Originally posted by 91BigRedz28
I
$300,i would say headers and exhaust if u dont have it already. another cheap good thing to have is an adjustable fuel pressure regulator.
Old Apr 24, 2004 | 09:23 PM
tom2's Avatar
I'd think the 91 TPI heads would be the aluminum hipo heads, the big Chevy heads would be iron low power standard heads. Probably looking at 25 HP difference in the two engines. For the 300 bucks, I'd go with headers and K&N filters, or put a set of high ratio rocker arms and a chip in the computer maybe.
squarehead
Jan 15, 2015 07:02 PM
Jan 13, 2015 09:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
pete53
Dec 9, 2014 07:31 AM
96z
Aug 2, 2002 09:00 PM
