Adjusting TPS on a SD ECM
Old Jan 19, 2004 | 03:28 PM
dj haf's Avatar
i heard you're not supposed to adjust the TPS voltage on a SD ecm. is this correct? if it isnt, what's the correct voltage to set it at? i know i need to use a DVM, but how should i check the voltage at WOT and what should it be at as well? thanks guys
Old Jan 19, 2004 | 09:15 PM
aklim's Avatar
I believe it should be aroun 0.54V
Old Jan 20, 2004 | 01:12 AM
90rocz's Avatar
MAF is .54 volts @ idle, 4.50volts @ WOT
SD is .70 volts @ idle, 4.50volts @ WOT
Old Jan 20, 2004 | 05:42 PM
92BLKL98's Avatar
My '92 isn't adjustable. The older models had slotted a TPS but the '92 don't.
Old Jan 20, 2004 | 09:58 PM
trackbird's Avatar
The '92 (and '91 I believe) will self adjust. They take the lowest reading they see and make it "idle" and go from there.
Old Jan 20, 2004 | 10:30 PM
dj haf's Avatar
91 and 92 are both SD... would it be safe to say my TPS will self adjust since it's SD ('90) and that i wouldn't have to do anything to it?
Old Jan 20, 2004 | 10:57 PM
aklim's Avatar
I would assume so. I knew the 91 and 92 are definately SD but I thought there were a few 90s roaming around that were MAF. I would bet that it would take the lowest value and assume that is the 0 deg throttle angle.
Old Jan 21, 2004 | 01:01 AM
90rocz's Avatar
I always set my Idle (air bleed) first, then if I have to, use a small dril to lengthen the TPS mounting holes. Usually only modifying one hole is enough, and adjusting one hole(side) will enable you to get good readings.
I don't think they "self-adjust", they're just a variable resistor will a 5 volt reference voltage applied.
Old Jan 21, 2004 | 10:03 AM
aklim's Avatar
They do self adjust from the standpoint that they take the initial voltage when you turn the key on to be idle.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
