Ignition upgrades
Old Jan 10, 2004 | 11:12 PM
splinter_cell's Avatar
Ignition upgrades
What would you guys recomend for ignition upgrades? Im told it will give me a less emissions, and a little bit better gas mileage and hp. Its for by 84Z which is basically stock except for 3"cat, flowmaster catback and open element. im kinda on a budget to so nothing to expensive Thanks.
Old Jan 10, 2004 | 11:49 PM
stanghunter211's Avatar
Most guys will tell you its a waste of money to add an ignition box to a stock motor. And unless you are running it up to like 5-6k rpm alot, it really is.
A nice start though would be some good wires, plugs, a better tha stock coil, maybe MSD blaster or something similar, and if you can maybe a perf distributor. All those will help out alot.
Will
Old Jan 10, 2004 | 11:56 PM
Pro
Guest
Posts: n/a
I noticed a much smoother idle and quicker starts when I put a blaster coil, taylor wires, and a MSD6A on both of my vehicles (the truck 3 years ago and the camaro a few months ago)
Old Jan 11, 2004 | 12:33 AM
Ok, decided to get new msd cap , msd rotor , blaster 2 coil , and Taylor Spiro-flow wires . These should be good right? I have a question about the blaster 2 coil though. Where do I put that? do I have to mount it somewhere? Also the plug wires are pre cut and everything. Should I go with them or universal? Thanks.
Old Jan 11, 2004 | 10:23 AM
gixxer92's Avatar
If the distributor is original, replace it. The bushings/bearings on the shaft wear and you get play in the shaft which can mess with timing.
84 = No computer and HEI style distributor
Look at this, it's a complete setup and you can beet the price for everything (if you have 200 to throw out there)
Pertronix Distributor @ Summit
Old Jan 11, 2004 | 12:51 PM
So since I have an 84 with no computer the blaster 2 coil wont work right. Will this work? I wish I could use 200+ to get that but I will have to wait.
Old Jan 11, 2004 | 01:43 PM
gixxer92's Avatar
you should have a HEI I think, not for sure. Someone else could cue in and help answer this.
I think this is what you need, if your coil is ontop of the distributor cap.
MSD coil
blkWidow
Sep 6, 2015 05:17 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BlackHawk T/A
Aug 28, 2002 03:13 PM
