How long to change front brake pads?
If the tires are off, how long to do it? And what specific tools do I need. Its freezing outside and I don't want to be screwing around. I already got horrible frostbite when my car got a flat a week ago. Thanks guys.
Yep, 2 allen bolts, either 3/8" or 5/16" (can't remember offhand.) You'll also need a big pair of channellocks or a 6" or larger C-clamp to squeeze the caliper piston back into the bore. You can probably get it done in 15 minutes if the wheels are already off.
THanks guys. My brother has done this a million times but its too cold to ask him to do it. I am excited, new rims, lugs, tires, balancing, alignment and brakes. Hopefully it will feel even better!
Might not be a bad idea to replace those rubber hoses anyways. New hoses are only about $12 and $13 dollars a side, but if you get them know that they are different for each side. You WILL need the bolt that holds the hose to the caliper though.
I put new rotors, seals, re-packed bearings, calipers, pads, and hoses on mine in just a couple of hours. Pretty easy job.
Working outside? I'd skip the hoses and bleeding for now. Get the pads on it and wait until spring (do a visual inspection, if the hoses are cracked, then it is time for new ones). And the allen bolt is a 3/8's allen (I use a 3/8 drive allen socket from sears or your parts store and a ratchet).
Stay warm!
Stay warm!
Skip the hoses and bleeding for now. When spring comes, get a set of braided steel hose. I did and it made the pedal a little firmer than it used to be. Not sure if it was because i had older rubber hose or whether it works better because there is less give in the hose.
Jul 4, 2005 05:00 PM
