92 RS 305 tbi won't start
Old Jan 25, 2004 | 01:04 PM
Gnboy's Avatar
my 92 rs will not start I cant hear fuelpump and I am not getting spark. however i do get spark at the coil any Ideas?
car ran fine night before but when I pulled in my driveway the service engine light came on showed a code 44 and the stared back up.the next morning it would not start
Old Jan 25, 2004 | 11:03 PM
nosfed's Avatar
iiiinnteresting I just got a couple third gens (after swearing I'd never own another F-body) and it didn't even make it out of the driveway.
Similar too, but I have PCM, no codes, good oil pressure, no coil, no fuel pump. Will be following this one, but I'd bet money a search will turn up the answer.
Old Jan 25, 2004 | 11:09 PM
krazzycowgirl's Avatar
Code 44 Oxygen Sensor (O2S), left side on 2 sensor system--lean exhaust indicated
Old Jan 26, 2004 | 12:40 AM
90rocz's Avatar
If you are getting spark at the coil but not at the plug, the cap & rotor or plugwires are bad.
If no spark and no fuel, then pickup coil is bad.
If you bypass the fuel pump relay by using the single little "red wire" that breaks out of the harness either near the battery or near the alternator, by applying 12 volts to it, the pump should run if good.
Old Jan 26, 2004 | 12:37 PM
nosfed's Avatar
In my case, I'm not getting fire or fuel. Coil has power at the pink wire. Are you sure the pickup coil is bad, and where is the pickup coil? I just checked, and the vats is working, and the pcm is powering and doesn't find any codes.
Old Jan 26, 2004 | 07:02 PM
Gnboy's Avatar
I have done a search closest match was simalar but they weren't getting any thing from the coil
plugs & wires 1 month old cap and rotor installed yesterday
Old Jan 28, 2004 | 05:31 PM
Gnboy's Avatar
update
car is still f!@%^
complete new distributor installed the pickup coil basket was broken on old distributor so I assumed that was it still no fire and no gas
Old Feb 5, 2004 | 12:30 PM
nosfed's Avatar
Got mine running, and it was the pickup coil. Unfortunately, I ruined the halo wheel getting the shaft out. Advanced Auto has a new dizzy, with a cap I walked out $102 poorer.
Sounds like Gnboy might not be getting pcm power. I returned your email I have access to a snap-on scanner that just rocks; it gives troubleshooting menus that pretty much tell you exactly what's wrong. If you answer the questions in that email, I'll get out that scanner and tell you what it says.
eazyZ
Mar 1, 2015 07:12 AM
Scottyboy
Feb 11, 2015 10:28 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Jessie4tin
Jan 7, 2015 08:53 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
