1987 IROC Z/28 RPO codes? is this a 1LE?
Old Jan 16, 2004 | 09:41 PM
brianchevy's Avatar
Here are my RPO codes and the description I looked up, according to this website below, I have an 87 1LE. How rare is this car? I am getting ready to race it in SCCA events.
http://www.iroc-z.com/articles/artic...vysupercar.htm
AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 : ADJUSTER, SEAT, POWER, 6 WAY
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B18 : ORNAMENTATION, INTR, DELUX
B3W : Advanced Price Sheet Processing Option
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B4Z : IROC PACKAGE
B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
B91 : ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
B94 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR I
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
C01 : ORNAMENTATION, EXTR EMBLEM, BODY, VAR 2
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DD8 : MIRROR I/S, R/V, LT SENSITIVE
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DK6 : CONSOLE ROOF, INTERIOR
D08 : PAINT, HIGH GLOSS FINISH
D34 : MIRROR, VISOR VANITY
D42 : SHADE, RR COMPT SECURITY
D7J : GEAR, SPEEDO DRIVEN
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
E5Z : SPEEDOMETER ADAPTER (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
GM3 : AXLE REAR, 3.45 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
G92 : AXLE REAR RATIO, PERFORMANCE
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 : COOLING SYSTEM, ENG OIL
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
N33 : STEERING COLUMN, TILT TYPE
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96 : WHEEL, 16 X 8, CAST ALUMINUM
PB4 : LOCK CONTROL, WHEEL
P20 : HUBCAPS, WHEEL, STYLED
QDZ : TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9 : LAMP, GROUP
TT4 : HEADLAMPS, HALOGEN, 4
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
UA1 : BATTERY, HEAVY DUTY
UQ1 : RADIO PROVISIONS, FOR STEREO
UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
NOD : ASSEMBLY PLANT, NORWOOD, OHIO
E72 : BODY LENGTH, INCR I8 INCH
E9Z : SPEEDOMETER KEY (DELETE)
U25 : LAMP, INTR, RR COMPT, COURTESY
U26 : LAMP, INTR, ENG COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
YR1 : SEAT,FRT CUSTOM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
1AZ : Order Modification, Orders Sold (or: CUSTOMER ORDERED VEHICLE)
1SC : PACKAGE, OPTION 03
15P : WHEEL COLOR SILVER METALLIC (91)
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
74Q : MOLDING COLOR, FLAME RED MET (91)
74U : PRIMARY COLOR, EXTERIOR, VICTORY RED (91)
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Old Jan 16, 2004 | 09:48 PM
Black6SpdTA's Avatar
Dude! I forget the exact number, but it is LOW. Double check the codes at www.thirdgen.org
Of course I'd still race it even if it was a rare car.
-Corey
Old Jan 16, 2004 | 10:13 PM
doug791's Avatar
you dont have a 1LE although i forget why not....There is something special that makes a 1Le what it is and there were almost none of that car made.
Old Jan 16, 2004 | 11:19 PM
f-bodybuilder's Avatar
Hey I'm lookin through thirdgen.org's technical database. Looks like they started being produced in 1988. Maybe you have one of the 4 that were made in 88......
Old Jan 17, 2004 | 12:33 AM
kevin 2.8's Avatar
1le's didnt come with foglights or a radio right?
Old Jan 17, 2004 | 02:45 AM
ZWILD1's Avatar
1LE's weren't sold for the '87 model year, nor do they come with a/c or cruise. Look near the bottom of your listing, you have a 1SC option level 03, not a 1LE option level 00. Once you specified option level 00, the factory automatically deleted a/c and cruise.
Old Jan 17, 2004 | 08:08 AM
Dave89IROC's Avatar
A/C and cruise could then be reordered on the car, but that was rare
Dave89IROC's Avatar
Old Jan 17, 2004 | 09:07 AM
unvc92camarors's Avatar
not sure about the radio but the fogs definately did not come on a 1le
that's one of the easiest ways to tell
sorry for bursting your bubble, i know it'd be great to own a 1le
course, it'd be great if i owned a car with a v8 in it anyways
Old Jan 17, 2004 | 10:17 AM
bmillington's Avatar
I think you get the radio and A/C back in the B4C option (cop cars), but no p/w,p/l or cruize control. And they come with RS decals.
Old Jan 17, 2004 | 10:55 AM
dewey316's Avatar
1LE cars also had 12" dual piston brakes and 36mm/24mm sway bars.
Old Jan 17, 2004 | 11:05 AM
Bristol's Avatar
I drive a 91 Z28 1LE 350CID automatic. I have a radio, P/W, P/B, P/M, P/S, P/seat, P/hatch, cruise etc. My buddy has exactly the same but a 92 with gray leather.
As for easy things to look for..... PBR aluminum brake calipers, 4 wheel disc, aluminum driveshaft, larger sway bars etc. are the most noticable but arent always guaranteed since people do 1LE upgrades.
Im probably wrong but I could swear that they did make like 2 1LEs in 87. The option code for a 1LE car prior to 89 was "A4U".
Old Jan 17, 2004 | 11:06 AM
Bristol's Avatar
oh if you do a search look for Hunter Motorsports. This guy used to race "R7U" s
Old Jan 17, 2004 | 11:22 AM
ZWILD1's Avatar
Dave,
Not to get into a shouting contest, but here is my understanding of how a 1LE was ordered in the early years:
- The customer ordered an IROC (not an RS) via RPO B4Z, IROC package
- specified RPO G92, performance axle ratio
- RPO G92 invoked RPO J65, rear disks; RPO G80, limited slip diff; and RPO KC4, engine oil cooler
- the customer then specified either RPO LB9, 5.0 TPI or RPO B2L, 5.7 TPI
- all IROC's automatically were assigned RPO 1SC - option level 03
- if the customer specified RPO 1SC - option level 00, there was no place on the order form to do this, the dealership had to contact the Central Order Processing Office to get approval
- if approval was granted, the car was assigned RPO 1LE
- RPO 1LE deleted the a/c, cruise, and probably power accessories(not sure though)
- RPO 1LE added, Corvette rotors and calipers on the front, an 18 gallon baffled fuel tank and a unique PROM in the ecm
RPO 1LE was meant to be limited to Showroom Stock racers with competition licenses. It was not meant for general release (Chevy learnt their lesson from the original RPO Z28) and the obtuseness of the ordering process reflected that.
Old Jan 17, 2004 | 11:27 AM
trackbird's Avatar
The B4C cars (cop cars) were 1LE cars with AC. But, for the first few model years, you could not get AC on a 1LE (it was built as a race car for competition use). Also, one of your RPO codes you listed would be "1LE" if it were optioned that way.
As memory serves me, there were 4 1LE optioned cars built in 1988 which was considered to be the first year of production.
This article seems to have some interesting info.
http://www.chevyrumble.com/News.asp?ID=26
