Where is the ECM grounded
Old Jan 19, 2004 | 11:17 PM
Pro
Guest
Posts: n/a
Iv been all through the chiltons and cannot seem to find where the main grounding location is.
From the archives I have read, it seems that I have a ECM problem (IE check engine light coming on randomly, not storing codes, speedometer not registering at times, engine hesitation, running VERY rich, etc). Im sure there is something else screwed up, but I dont have the money to pay a shop to fix it right now (the truck is currently getting worked on) and if it is a simple wiring problem.... how nice that would be.
Old Jan 20, 2004 | 01:07 AM
90rocz's Avatar
The engine harness including ECM is usually grounded on the rear of one of the heads near the firewall.
Old Jan 20, 2004 | 01:39 PM
tom2's Avatar
Main grounding point on pass head rear top. Real hard to get to. Had ongoing problems with my 89 and finally traced it to this ground, all black and charred, some real current goes through there.
Old Jan 20, 2004 | 02:14 PM
Pro
Guest
Posts: n/a
What do you recommend doing? Just clean off the surface or find a new grounding spot?.
Old Jan 20, 2004 | 02:25 PM
Pro
Guest
Posts: n/a
Old Jan 20, 2004 | 10:59 PM
aklim's Avatar
I would clean off the surface and find a new grounding cable. The spot is fine and the cable might be bad.
Old Jan 21, 2004 | 12:57 AM
90rocz's Avatar
You need to sand off the area of the head where the ground bolts on, and the ground "eye-connector"end on both sides. Get some dielectric grease and put a light coat on both sides of the eyelet, bolt it back down and liberaly coat the bolt and connector end with the grease.
Make sure your "engine-to-firewall" ground strap is still in good shape too, a flat braided steel wire...
Old Jan 21, 2004 | 10:02 AM
aklim's Avatar
I can't be absolutely sure right now but I thought there are 2 grounds?? One to each side of the head?
Old Jan 21, 2004 | 10:47 AM
Pro
Guest
Posts: n/a
Iv had absolutely no time to mess with the camaro (I work 7:00am until midnight today, for instance), but it is easy to get to the grounding spots from under the hood? Or do I need to schedule an appointment with a shop while im here at work.
Old Jan 21, 2004 | 01:02 PM
angel71rs's Avatar
In case grounding isn't problem: I had to replace the ECM in my Formula in November; I suspected it of causing random flooding. Wasn't sure if it was the problem, so I dropped it down (takes a few minutes), fired up the engine and gave ECM a rap with my knuckes. Engine skipped. Gave it a hard knock and engine died. R & R'd the ECM, problem fixed.
Old Jan 22, 2004 | 05:13 AM
aklim's Avatar
It is something you can do by yourself. In any case, try it first. Schedule an appointment after the weekend and try it during the weekend. If you suceed, cancel the appointment.
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
autoxr166
Sep 25, 2015 04:21 PM
frankrizz
Sep 23, 2015 04:21 PM
92_RS_305
Sep 8, 2015 07:47 PM
