Effects of not having o2 sensor
Old Jan 28, 2004 | 11:27 PM
splinter_cell's Avatar
Hey guys, i might buy some headers that dont have an o2 bung. IF i get them what do I do about the o2 sensor? just unplug it? will it set off any codes? how much would it cost to have an O2 bung welded in?
Mike
Old Jan 28, 2004 | 11:51 PM
BigCasino87GTA's Avatar
From: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
it will most likely set off a code, you will also fail the emissions portion of your inspection. Better of just getting the headers with the o2 bunghole in 'em.
doug791's Avatar
haha you need an O2 sensor, the computer will go nuts throwing codes and your car will run like a dog because the computer relies largely on that to calculate your air/fuel ratio.....a bung should be cheap to have welded in by any exhaust shop
Old Jan 29, 2004 | 12:35 AM
aklim's Avatar
It will set a code, throw your car in "Limp" mode (no power) and your cruising gas mileage will definately suffer and probably also the city mileage too.
Old Jan 29, 2004 | 05:42 PM
RedIrocZ-28's Avatar
Yup, you'll go to open loop and rely on your MAF sensor rather than the O2. You may not notice a significant power loss but its a pain in the *** to drive the car without an O2 sensor. It'll surge at idle if you have modified anything. While the factory style O2 sensor isn't really all that accurate, its way more accurate than your open loop programming. (open loop is your "warm-up" stage if you will) So, do everything you can to keep that O2.
Old Jan 29, 2004 | 09:40 PM
aklim's Avatar
Won't there be a power loss when the car goes into limp home mode? Since there will be 0 V coming from the sensor, won't the ECM see it as an extremely lean condition and try flood the engine with more fuel and screw it up?
Old Jan 29, 2004 | 09:45 PM
Black6SpdTA's Avatar
Yep, Limp Mode = Bog the motor full of fuel Mode.
Old Jan 30, 2004 | 12:42 AM
IROC-T's Avatar
Have the bung welded in before the install,should be able to talk some welder into doing it for a six pack,and the bung is about $5 so it'll be about $12-$15. Depends on what kinda beer the welder drinks.
Old Jan 30, 2004 | 02:40 AM
aklim's Avatar
Not sure if this applies but I once had the driver side of the injectors shorted out and the O2 sensor kept reading an extremely lean conditon. It would flood out the motor. Finally found it when we examined the pulse width of the injectors and found they were about 2.8ms when they should have been around 1.5ms.
Old Jan 30, 2004 | 11:38 AM
kevin 2.8's Avatar
just drill a hole weld in the bolt that holds the o2
Old Jan 30, 2004 | 10:30 PM
aklim's Avatar
How about getting this?
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Noct
Jul 14, 2015 01:18 AM
