Rear End Gear Change (G80)
Old Jan 11, 2004 | 04:44 PM
Ville H. Valo's Avatar
1st off, I was recently informed I have a G80 positive traction rear end. I want to know how easy it is to change gears in the rear end, I also want to know my ratio (G80) and a good gear ratio for good acceleration. How many bolts is the G80 rear? What is the difference between 3.08 and 5.57 gears? Also if I was to switch to a gear that gave me better acceleration how much of a difference could I/ would I notice? Thanks,
-Ville H. Valo
Old Jan 11, 2004 | 05:05 PM
aklim's Avatar
What are you doing with the car? My car had 4.10s and took a tank of gas to go 200 miles. With 3.73s, they went about 220 in the city and 300 highway. What engine combo?
Old Jan 11, 2004 | 05:10 PM
i just want the car to accelerate more quickly. so if i got 5.38 it would be jummpy???? <=========bad gas mileage?
Old Jan 11, 2004 | 05:22 PM
aklim's Avatar
5.38s? How much money do you make? You better have a tanker at your house for your fillups.
I think 3.73s will be more than you need unless do have done something radical.
Old Jan 11, 2004 | 05:29 PM
i have a LB9, what is the gear ratio on a stock G80 rear end. would 4.10 be good? how hard is it to change?
Old Jan 11, 2004 | 05:37 PM
aklim's Avatar
It would be too much. Your cam and gear needs to be matched. If your gear pulls your RPM range out of the abilities of the engine, you will not have good acceleration. 4.10s are marginal when it comes to a daily driver. Believe me, I have been there and done that and regretted it. Also, you will have to get a speedo gear fix in the tranny because there is no direct fit set of drive and driven gears where there is for the 3.73.
You could pay thru your *** for a GM set or get a Richmond Gear set for under $200. GM ones are, I believe, a little under $400. If you have to ask the question, you are not capable of doing it yourself. You will need a professional who has the tools and the ability to follow Richmond Gear's instructions to the letter. I had a mechanic try to use GM's instructions and the gears howled. To quieten it, you will have to follow their instructions to the letter. My tech who has been doing it for years had to take it in and out 4 times to get it just right. You have to adjust it according to their specs and there is where the fun begins. Now you have to take a wear patter test and if that isn't right, take it out and reshim till you get the pattern right. You need a dial indicator and know how to use it and some other special tools to make it easier.
After all is said and done, your speedo will be wrong and hence your VSS reading will be off. Now you have to take the tail of the tranny off and put in a custom drive gear on the shaft and put a custom driven gear on the vss. I believe LPE sells them for around $125 or so.
Old Jan 11, 2004 | 05:39 PM
aklim's Avatar
You would need the GU* number for us to know. When you have it, I can look it up and tell you tomorrow.
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
5.38 is an insane rear gear. I rarely see more than 5.13s even on drag only cars.
3.73s are a nice street gear. I prefer 3.55s if you have TPI, cause it produces plenty of torque down low so you dont need the extra gear to make up for it. Plus TPi dies at high RPMs anyway so you dont wanna ooutrun your powerband by overgearing it.
Black6SpdTA's Avatar
G80 isn't a rear gear code. Run your RPO's at www.thirdgen.org. Like aklim said, 3.73's That's what I've got (sitting in garage ready to go in). The higher the number (lower the gear) the faster acceleration and lower MPG. Vice versa.
-Corey
Old Jan 11, 2004 | 05:46 PM
aklim's Avatar
Not if I am selling him gas by the truckload.
Old Jan 11, 2004 | 05:47 PM
aklim's Avatar
GU1 : AXLE REAR, 2.41 RATIO
GU2 : AXLE REAR, 2.73 RATIO
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
Linky
Old Jan 11, 2004 | 05:56 PM
ok i have GU4 or 3.08, so what gear is recommended i use? 3.73?
Old Jan 11, 2004 | 06:02 PM
aklim's Avatar
I wouldn't go past that for a LB9. 3.55 or 3.73 would be alright for the street. Of course, if you plan many more mods in the future like say changing the tranny to a 200R4 or a T56 where you have a super low overdrive, you might be able to get away with 4.10.
Old Jan 11, 2004 | 06:10 PM
i have a t5 right now...
Old Jan 11, 2004 | 09:27 PM
aklim's Avatar
My money would be on the 3.55s unless you are planning a bunch of mods later. Are you?
