91 RS 305 questions
Old Feb 1, 2004 | 02:37 PM
94formulabz's Avatar
91 RS 305 questions
Sup guys, I'm considering buying a 91 RS to use as a commuter.
Any SBC head will bolt up to the 305 correct?
How many FWHP can that stock bottom end take?
What RPM can a stock 305 take before ripping itself apart? (assuming some heads to feed it)
I'm not looking to make this thing into a racecar, I'm just wondering what the limitations are for a mild workover on a budget.
thanks in advance,
-brent
Old Feb 1, 2004 | 02:59 PM
Black6SpdTA's Avatar
Re: 91 RS 305 questions
Yes, but if the heads are for a 350+CI motor, have them milled or your compression will go in the crapper. 305's have the same crank as a 350 so figure around ~6k before pistons start flying
FWHP--Once again, same crank/rods/pistons (smaller bore though) so probably the same as a regular 350.
IMO, As a commuter I think the perfect car would be a 98+ Camaro V6 M5. About same performance as a 305 RS, little better actually, (believe it) and better gas mileage. Plus just a newer, most likely more reliable, user friendly car. Price is a differrent story though. Either way, good luck!
-Corey
Old Feb 2, 2004 | 07:26 AM
axoid's Avatar
6,000 rpm is about the safe limit. With a stock L03 you'll have a major power drop off well before 6 grand. With my modified L03, I often see over 6 grand when autocrossing (new heads, intake, cam / stock short block).
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
printer61
Feb 27, 2015 07:43 AM
markaubuchon
Jan 14, 2015 01:48 AM
