Chassis evolution?
Old Jan 16, 2004 | 07:36 PM
chevyman502bb's Avatar
Chassis evolution?
how different were the frames from the 3rd gen to 4th gen? i saw a post either in the lounge or 3rd gen tech about the mustang only havin a chassis change once in like 20 years or something and just got me thinking as to how different the 3rds are from the 4th......
Old Jan 16, 2004 | 07:59 PM
TheGreatJ's Avatar
The rear subframe and floorpan is close enough that everything swaps over pretty easily. The front subframe is generally the same shape, but a little different to accomodate the coilovers, rack, and upper/lower control arm setup.
Old Jan 16, 2004 | 08:10 PM
so thats why the 4th gen front clip bolts into the 3rd gen so easily?
Old Jan 16, 2004 | 09:11 PM
Black6SpdTA's Avatar
What do you mean when you say "front clip?"
Old Jan 16, 2004 | 10:17 PM
like all the front suspension assembly n ****
Old Jan 17, 2004 | 10:58 AM
dewey316's Avatar
i would not say it is easy, or use the term 'bolt in' if you are talking about doing a whole front suspension swap from generations.
i have seen/heard about ONE car that has a full 4th gen front end conversion, and IIRC it took a ton of work.
Old Jan 17, 2004 | 11:17 AM
Aaron91RS's Avatar
c4 vette IRS's seem to go in to 3rd gens too if, but I wouldn't consider either a bolt in.
Quickss96
Jan 29, 2016 05:56 PM
alliance12364
Sep 23, 2015 12:40 PM
97blackformula
Aug 27, 2015 06:02 PM
alphaauto
Jul 26, 2015 04:40 PM
Richardan15
May 30, 2015 08:36 AM
