Trans Am rear end
Old Jan 29, 2004 | 06:25 PM
redlined4816's Avatar
Trans Am rear end
Does anyone know the stock gear ration out of an 86 trans am? and that is posi , stock, right?
Old Jan 29, 2004 | 06:27 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
There are several avaliable ratios. Need more info to tell you properly. Some are posi some arent.
Old Jan 29, 2004 | 06:49 PM
ok..
do you know how i would be able to tell?
the car was a 305 tpi auto, i might be able to get the vin number but thats about it, car was junked an i only have the rear end and want to know what it is
Old Jan 29, 2004 | 09:11 PM
Stephen 87 IROC's Avatar
Not sure about the TA but an 86 Camaro with a 305 TPI auto came with 2.73 gears and had an option for 3.42 (G92 option)
Old Jan 29, 2004 | 09:39 PM
Black6SpdTA's Avatar
Turn the wheel (if no wheel, just the hub) one full turn. Count the number of times the yoke turns completely over.
Aprox. 3.5 turns = 3.42
2.75 turns = 2.73 Etc. Etc.
Old Jan 30, 2004 | 10:21 AM
Marc 85Z28's Avatar
The easiest gear ratio test would be to tell us at MPH the trans shifts from 1st to 2nd gear at WOT. Most likely you have 2.73s.
The easiest limited slip (positraction) test would be to nail it from a stop. Do both tires spin? If yes, it's a posi. If not, then it's either an open rear or fried posi.
Old Jan 30, 2004 | 10:27 PM
aklim's Avatar
Get the RPO codes and go here and figure it out for yourself.
Old Jan 30, 2004 | 10:40 PM
From what he said up top he's only got the rear. Not in a car. I thought if you spin one wheel and they go the same way, posi. If they spin opposite ways, open?
Old Jan 30, 2004 | 11:37 PM
um no
ok captain first of all its the same car
Old Jan 31, 2004 | 04:16 PM
841LE's Avatar
Rippin92rs has the easiest way to tell.If its off the car.Mark both the wheel/hub & your yolk first.then turn the wheel one complete revolution.Watch the mark on the yolk & count how many turns it makes.This will give you a very close idea of the ratio(example,if the yolk makes 2 &3/4 turns).you more than likely have a 2.77 ratio.If both flanges/axles turn in the same direction its a posi.There is also a code on the pass axle tube.But youll need a service manual/chilton/haynes(or other) to look up the code.Which then tells you what ratio.
dawg irocz
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
