Firing Order on big block
Old Jan 25, 2004 | 04:16 PM
1984camaroz28's Avatar
Firing order on the big block is Clockwise or counter clockwise
Old Jan 25, 2004 | 06:12 PM
need help fast this is holding me up from running it
Old Jan 25, 2004 | 06:15 PM
jms's Avatar
jms
Exact same way as a small block.
Clockwise retards timing.
Counter-clockwise advances timing.
Same firing order as small block--1-8-4-3-6-5-7-2
jms
Old Jan 25, 2004 | 06:46 PM
so the rotor turns clockwise or conter clockwise
Old Jan 25, 2004 | 07:33 PM
Dave89IROC's Avatar
clockwise
Old Jan 25, 2004 | 07:55 PM
yea thats how i had it........ Its outa time gota start from squar one again
Old Jan 25, 2004 | 09:00 PM
trackbird's Avatar
Did you get it 180 degrees out? IF you left the cam dots at the 12 and 6 o'clock positions, it is on cylinder 6, not 1. If so, lift the distributor, spin it 1/2 turn, set it down and try again.
Good luck!
grabbem88
Mar 18, 2015 01:25 PM
MadMav
Feb 6, 2015 11:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
Eric H
Aug 10, 2002 06:39 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
