T-5 vs T-56
Old Jan 22, 2004 | 09:39 PM
Lotus Outermost's Avatar
T-5 vs T-56
I've heard the T-5 is lighter than the T-56.Can I get some good and bad things about both trannys?thanks
Lotus
Old Jan 22, 2004 | 09:44 PM
OneSickS10's Avatar
T-56's can handle a boatload more powerthan the T-5's.
Old Jan 22, 2004 | 09:45 PM
Rice Killer87's Avatar
the T-56 is a 6 speed (im sure u knew that) so its gonna get a little better gas mileage,having like 2 overdrives. it can also handle alot more HP than the T-5...ive heard around 450 or so for the T-56 (correct me if im wrong...im not a big manual tranny guy). what are u thinking about putting it behind? like cubic inch...HP...plans in the near futre...etc.
Old Jan 22, 2004 | 09:49 PM
OneSickS10's Avatar
yea, probably 450 - 500 they use those tranny's in the Vipers also.
Old Jan 22, 2004 | 10:12 PM
Beast5spdGTA's Avatar
T-56 handle at least 450 ft*lbs, probably more, .50 6th gear OD weight ~60 lbs more than a T-5
T-5's have "better" shifting IMO, work with stock hydraulics for the clutch. And generally break when slicks and powershifts are applied at any power level.
I've never broke a T-5, but one is definately wounded, I don't powershift anymore and only run street tires. mid 14s sec 305 and low 14 sec 350, drive hard everyday.
Old Jan 22, 2004 | 11:09 PM
trackbird's Avatar
T5 is about 98 lbs and rated for between 275 and 325 ft lbs (depending on year and "World Class" or not). The T56 is about 155 lbs and there are a few cars making 700 hp running them with no real trouble (if you "beat them up", they still break).
The Viper version is different than the 4th gen version. It has a larger input (and output as I remember) shaft and several other modifications. But it is a great upgrade from a t5 and teh LT1 version is an easy swap into a 3rd gen. I have put a t5 in an '89 Formula and a T56 in an '84 Camaro. One was not any more difficult than the other.
Old Jan 23, 2004 | 12:24 AM
97WS6SCharged's Avatar
The Viper also got cast iron shift rods (forks? I don't remember exactly what) while the f bodies got aluminum. If you're going to run a high horse motor, upgrading to the iron version is worth it. I believe there is also a company making them from billet steel, but be prepared to fork out some $$ for those.
Old Jan 23, 2004 | 08:19 AM
trackbird's Avatar
D&D Performance has the upgraded parts for sale.
G-BODYT56
Jan 14, 2022 11:14 PM
Henson071
Dec 30, 2015 09:55 PM
Chris`s85Z28
16
Jan 27, 2003 11:27 PM
VentsWoker
West South Central
Nov 17, 2002 03:29 PM
86 redbird
21
Oct 9, 2002 04:49 AM
