SFC Install
Old Jan 11, 2004 | 10:03 PM
slayer6x6's Avatar
SFC Install
What is involved in installing a set of subframe connectors in my 86 IROC. What are some advantages/disadvanges between bolt in and weld in subframe connectors. Are the bolt in subframe connectors something Im able to do in my driveway?
Old Jan 11, 2004 | 11:32 PM
Chuck!'s Avatar
Advantages: everything
Disadvantages: you'll cry you didnt own them before.
Bolt-ins are ok, but over time the holes where they're bolted will elongate and you'll get some slop. However, all the bolt in ones should be able to be welded in later if you're in a pinch for money now and want them now.
Old Jan 12, 2004 | 12:08 AM
billsbird's Avatar
Slayer, yes its a job that you can do in your driveway. Although put the car up on ramps or jack stands. I put 'em on my '84 Camaro years ago and it really wasn't any big thing. Bill...
Old Jan 12, 2004 | 12:12 AM
billsbird's Avatar
EDIT! Slayer, don't use jack stands as the car must be at ride hight. I'd forgotten that part, I did it like 10 years ago or so. Just get it up in the air for ease of installation but have all 4 wheels/tires supported.... Bill...
Old Jan 12, 2004 | 01:35 AM
aklim's Avatar
Got alignment rack? Got welder?
Old Jan 12, 2004 | 08:35 AM
Black6SpdTA's Avatar
Not too bad. We installed them Sat/Sun. Pass side can be tricky. We had to disconnect a lot of the exhaust and do some prying. Pretty straight forward. I opted for the bolt-in Jegster SFC's. They really stiffen up the ride, definitely worth $180. I'm welding them in later. Good luck.
-Corey
Old Jan 12, 2004 | 01:33 PM
slayer6x6's Avatar
I do have access to an alignment rack, but I dont know anyone with a welder.
Old Jan 12, 2004 | 06:03 PM
Just finished the write-up of my SFC install. Instructions/Pictures Check it out: http://www.cardomain.com/memberpage/400090/7
-Corey
Old Jan 12, 2004 | 06:15 PM
aklim's Avatar
I suggest you get someone to do it for you instead of bolting it on.
Old Jan 12, 2004 | 09:38 PM
slayer6x6's Avatar
Thanks for the write up rippin, Ill probably just bolt them in on the alignment rack then take it somwhere to finish on the welding.
Nov 18, 2023 07:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
