O.K. Time for the LT1/ Any good links?
Old Jan 24, 2004 | 11:09 PM
stk350's Avatar
I'm pretty sure I have the basic idea of how to do the swap. Anyone have any good links?
Old Jan 24, 2004 | 11:16 PM
Black6SpdTA's Avatar
The motor swap forum on www.thirdgen.org has all the answers you can ask for. And some guys on there (TexasLT1, mat89rs, etc) will answer whatever you need. Good luck, got the motor yet?
-Corey
Old Jan 25, 2004 | 12:35 AM
Zepher's Avatar
Save up and get the LS1.
Old Jan 25, 2004 | 01:16 AM
ThirdgenTa's Avatar
Are you swapping engines or just the intakes?
If just the intake, www.lt1intake.com
Old Jan 25, 2004 | 01:25 AM
tamatt27's Avatar
http://thirdgen.org/techbb2/showthre...hreadid=219753
Old Jan 25, 2004 | 11:05 AM
Good call. Unless you've got the motor already, just swap intakes. There are no other "real" advantages of the LT1 over a typical 350 SBC. Once again if you don't have the engine yet...I agree with Manny, get an LS1
-Corey
Old Jan 25, 2004 | 12:29 PM
stk350's Avatar
I found an LT1/T56 combo I can't really pass up. I've got all kinds of probs with my current harness, electrical, A/C ect. It's just time for somethig new. On top of that, a buddie of mine has a 95z that runs deep into the 11's. We're are going to build me the same setup. Thanks for the links, keep em comming.
Old Jan 25, 2004 | 07:15 PM
FastWhiteTA's Avatar
There are lots of advantages besides the intake.
-Better heads
-Reverse cooling system is better
-The ignition system is better (although some people think the opti is bad, it works well when working properly)
-Stock for stock the cams are better (slightly)
-fuel injectors are better (24#s / hour, and they don't clog as easy)
Be sure to get the LT1 fuel pump as well, cause it's better than the L98 one as well. See, the list goes on
Technology improved on the LT1 over the earlier SBC versions, just as the LS1 is above the LT1 in the food chain.
Old Jan 25, 2004 | 07:29 PM
Dave89IROC's Avatar
92 and 93 LT1's still used 22# ones
Old Jan 26, 2004 | 09:25 AM
LT1Powered85Z's Avatar
Check out my site if you'd like.
Eric
Old Jan 26, 2004 | 10:55 AM
stk350's Avatar
Hey LT1poweredz do you have any pic's of where you had to notch the K-member?
Old Jan 29, 2004 | 12:06 PM
stk350's Avatar
Need more links and pic's
Feffman
Oct 9, 2015 05:42 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
rockync7
Jan 1, 2015 05:10 AM
DrMilhouse
Aug 6, 2002 08:45 PM
sc93
Jul 26, 2002 02:02 PM
