Question on brake job.
Old Jan 15, 2004 | 04:01 PM
Rage's Avatar
I did a complte front brake job on my car today. I cut the rotors, packed bearing, greased everything up good, compressed the piston, and replaced the shoes. Now, when Im driving my car, when I stop, I can smell a burning smell, and if I go high speeds and stop, smoke will come from the brakes. What's the deal? Did I do something wrong or are they just going to do that till they get worn in?
Old Jan 15, 2004 | 04:47 PM
jzajac1's Avatar
Couple things to check for..Did you over tighten the wheel bearing nut? Is the car pulling to the left or right when applying the brakes which would indicate a sticky caliper. Did you check your caliper to knuckle clearance so the caliper has enough room for heat expansion and can freely move back and forth when they get hot and expand. Did you clean your caliper bolts and put anti-seize compound on them? Did you pull the caliper bolt bushings out of the caliper ears and clean up any corrosion and also put anti-seize on them? How were the brakes before you did the brake job?
Old Jan 15, 2004 | 05:26 PM
Rice Killer87's Avatar
sounds like u might have gotten some grease, WD-40 or somethin on the pads (shoes are for drum brakes,just so u know) or maybe somethin on the rotor. jack it up and take the tire off and see if there something on the rotor. try turning the rotor by hand also,it should have only a little bit of resistance.
hope that helps
Old Jan 15, 2004 | 05:55 PM
Rage's Avatar
Thanx. Think its just bearing grease on the rotor. When I was pulling the rotor off the brake lathe, I got some grease on it, how long should it take to get it all off?
Old Jan 15, 2004 | 06:45 PM
greezemonkey's Avatar
Were the caliper slides nice and free? these little short "tubes"
that the pin goes thru lock in position and hold the inboard pad aganist the rotor causing the pad to press on the rotor all the time.
Old Jan 16, 2004 | 10:10 AM
aklim's Avatar
Before I install rotors I always clean them with brake cleaner and do the same to the pads. Try that.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rwferguson43026
Feb 6, 2015 10:06 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
