what year did the SBC go to the 1pc rear main seal?
Just curious if anyone here knows. I'm searching for a 1pc rear main 2bolt 350 block for a rebuild. I have a 2pc, but since I'll be using a f-body 6 spd, I'd rather save the $$$ than spend it on the centerforce flywheel needed.
Anyone know for sure?
From: Teeter-tottering between Brilliance and Insanity
However remember that no Camaros were produced with a 350 in 86, they were all 305s. SO if someone tells you they have an 86 f-body with a 350 they either have a swap or they are lying. GM didnt put 350s back in them till 87
Originally posted by gun4hire
Well, I wont be looking for a whole car - just a shortblock. With the heads off, I should think I can ID the 350 vs. the 305. Thanks for the advice though!
Originally posted by Pasky
Wrong! Their were Iroc-z's produced in 86 with the 350, however, only 74 were made.
go to www.gtasourcepage.com....www.thirdgen.org...
1987 was the year the 1 peice RMS and centerbolt heads started production...
Originally posted by MY91Y84
Dude the L98 wasnt avaiable to the public untill 87...theres no 2 ways about it,...everyone and there brother knows someone with a 86 roc with a 350...BTW the "real number" was 50 not 74...None were sold to the public, IF there were any built they were used as mules then destroyed...and theres no proof they were even built
The guy needed to know what year block to look for.
1987+ buddy - Hydraulic Roller, 1 Pc. RMS, Centerbolt
I've always seen the Car V8's had a one-pc seal in '86, but trucks had either or. It's confusing b/c of all the replacement engines with 2-pc'ers and production engines with 1-pc'ers floating around together. A lot of warantee replacments etc..
In 1986, Chevy started with the 1 piece rear main seal, but left the standard 4 bolt flange valve covers and the flat tappet cam in the motors. In 1987 GM changed to the centerbolt valve covers and roller cam. I spent many years working at parts stores selling replacement motors (and taking cores back), working on F-bodies and then did a few years at Jegs in tech support (for anyone who wonders who I am and how would I know). However, the 1986 block castings are not setup for the roller cam. So, you may want to consider a 1987 and up block to save money on the roller bits.
I've seen a few truck blocks with the "bosses" and the deep lifter bores for the roller cam, but the bosses weren't tapped and it didn't seem to be worth the effort to tap them for the conversion.
Hope this helps.
Good luck!
(I miss my 3rd gen....I keep thinking of selling the new Z-28 and buying another 88 or 89 Formula.....)
Hope this helps.
Good luck!
