How much horse does a LB9 have?
Old Jan 8, 2004 | 11:52 PM
Ville H. Valo's Avatar
i was wondering how how much hp a stock 1992 Camaro z28 with a 5 speed would have. ive been looking around and i think it has 230 hp. is that right?
Old Jan 9, 2004 | 12:59 AM
lil305gta's Avatar
That is correct. The auto tranny models range from 190 to 215 depending upon the year.
Old Jan 9, 2004 | 01:38 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
It depends on how many catalytic converters your car has and which options. If you have two cats with the G92 option and disc brakes, then its 230 HP. If you have the single cat with drum brakes, then you have 205 HP. The difference is the 230 HP models have a much better exhaust.
Old Jan 9, 2004 | 04:21 PM
im pretty sure i dont have the G92, so that means i have 205 hp? i hope not, that would suck....
what was lil305gta saying about the auto vs. the manual?
it seems like i have more horse that 205hp.
Old Jan 9, 2004 | 04:28 PM
Black6SpdTA's Avatar
Auto vs. Manual: Manual cars got a larger cam (L98 cam if IIRC).
Just put a good flowing catback on. She'll sound sweet too
-Corey
Old Jan 9, 2004 | 04:37 PM
so i have a 305 with a 5 speed, do i have 205hp? or 230hp?
Old Jan 9, 2004 | 04:47 PM
Check your RPO codes. G92 is what you're looking for. It's 3.42 gears I believe (might be 3.23?)
-Corey
Old Jan 9, 2004 | 04:51 PM
how do i check my RPO codes? i am assuming that is a very dumb question.
Old Jan 9, 2004 | 04:59 PM
91 GTA Ramair2's Avatar
I see no not really a dumb question....
In your center counsil there is a sh*tton of number's those are your repo codes...
Old Jan 9, 2004 | 05:32 PM
ok, i looked, the closest thing to g92 was g80. what the hell does that mean.
Old Jan 9, 2004 | 11:47 PM
MY91Y84's Avatar
G80 is posi...GU6 is 3.42 gears...G92 is a performance package which was the 3.42's and some other nice stuff
you car probly has 3.08 gears, in which case you have 210 ponies
Old Jan 10, 2004 | 12:10 AM
Pro
Guest
Posts: n/a
At least he has a manual. A NICE platform to throw in a 6 speed.
Old Jan 10, 2004 | 10:46 AM
Kevin91Z's Avatar
-Corey
No, all 90-92 305 TPI engines got the L98 350 cam, regardless of options. The 205 HP vs 230 horsepower difference is partly marketing, and partly the exhaust difference. The 205 HP cars have the TBI 2 1/4" exhaust, while the 230 HP cars have dual cats with the TPI 350 2 3/4" exhaust.
Since you didnt find G92 in your RPO list, that means you have the 205 HP engine with the smaller exhaust. I trust you also only have a single cat, drum brakes, and you have GU2 in your RPO list for 3.08 rear end gears.
Its not the end of the world to have a lower performance TPI thirdgen. Be thankful you didnt buy a TBI car.
Old Jan 10, 2004 | 11:50 AM
Angry Thats your opion..........
Stock TBI suck's a$$ but after market TBI system's seem to kick some major A$$
Old Jan 10, 2004 | 11:57 AM
I'd take TBI over and L-98 100 times over.
s**t I'd take an LB-9 over and L-98 .
I've had a few 2-TBI car's they perfromed well.......
69 Amx 390 Dual Quad TBI's ran the best of 9.63@143mph....
then I got the 91GTA that some one swapped in an LO-5 it ran 14.80's @ 95.87mph. ran 3 times.
my LB-9 was running only 15.50's @ 93.37mph but it was still decent ...... Ran 4 time's.
then i got my L-98 and RIPped off a 16.11@88.9mph.
But I only ran it twice and the TBI car's did get 3 run's each so i guess the L-98 was at a disadvantage.
now i'm debatting to Try and fix The L-98 or just blow it up and get real engine like nice 327,400,427.............
MDZ28
11
Sep 24, 2015 09:15 AM
cmsmith
Sep 14, 2015 09:25 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Jul 17, 2015 02:47 PM
NewsBot
May 16, 2015 04:00 PM
