Electric fans
Old Jan 17, 2004 | 08:27 PM
Pro
Guest
Posts: n/a
Electric fans
Are they supposed to be on when just turning the key AND NOT being in diagnostic mode?
Old Jan 17, 2004 | 09:20 PM
Pro
Guest
Posts: n/a
Exclamation
if someone could just walk outside and turn the key and see....
Old Jan 17, 2004 | 10:00 PM
TheGreatJ's Avatar
Only if it's hot enough to kick them on, or possibly if the A/C switch is on. If the A/C is off and she's not hot and they're coming on with the key...they're either straight-wired or you have a bad fan switch/relay.
Old Jan 17, 2004 | 10:10 PM
Pro
Guest
Posts: n/a
The car is cold and the AC isnt on. The car constantly thinks it is in diagnostic mode I suppose.
Old Jan 17, 2004 | 10:22 PM
IROC-T's Avatar
I don't think your car is in diognastic mode,I agree with TGJ that your fans are straight(hard wired)wired,or your relay is stuck,or a bad temp sensor.
Old Jan 18, 2004 | 10:13 AM
TheGreatJ's Avatar
They shouldn't come on in diagnostic mode IIRC. I know when I hook one to my Snap-On scanner to pull codes at work they don't come on.
Ford vehicles will turn them on for a few seconds during a KOEO diagnostic test, but as I recall GM cars won't do it unless you're running an ECM output test (checking relays and such.)
Check your wiring. Straight-wiring the fans is a common band-aid for these cars.
Old Jan 18, 2004 | 10:22 AM
Pro
Guest
Posts: n/a
What do you mean by straight wiring - that whenever the ignition is on or vehicle is running, that the fans are turning? If so, they cant be - the fans turn off when the vehicle is started.
Jmj93z28
Jul 8, 2015 10:01 PM
Koby
Jun 28, 2015 04:46 PM
Jul 4, 2005 05:00 PM
tbyrne
Jul 2, 2002 05:37 PM
