another engine question
Old Jan 19, 2004 | 06:00 PM
CGCBandit's Avatar
hello again...my question is, will a 1.6 rocker fit under the stock 87-up centerbolt head valve cover. I know you gotta but the special narrow body rockers, but will a 1.6 fit under there, or do I have to buy taller valve covers? TIA
Old Jan 19, 2004 | 06:47 PM
jzajac1's Avatar
The GM (Crane) will fit but on some valve covers you have to slightly bend the baffle in the valve cover with a pair of channel locks. I've experienced a good fit on my 350 and on my son's 350 I had to bend the baffle slightly. Can.t explain the difference but they do fit....
Old Jan 19, 2004 | 09:19 PM
aklim's Avatar
I don't think the height of the VC will make that much of a difference. You can grind the webbing away or get the crane gold RR in narrow body which will work very well. I did and am using the stock VC.
Old Jan 20, 2004 | 12:04 AM
trackbird's Avatar
I used Harlan Sharp roller rockers under the Moroso centerbolt valve covers and they worked just fine. Those valve covers seem to have a little more room underneath then the stockers do.
Old Jan 20, 2004 | 04:34 AM
CGCBandit's Avatar
Thumbs up
Ok, thanks everyone.....this place is gr8 for info
oldschool
Feb 9, 2016 09:21 PM
ChrisFrez
Jan 11, 2015 03:47 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
ChrisFrez
Nov 23, 2014 10:33 AM
