Best way to tow a third gen
Old Jan 18, 2004 | 10:11 AM
Pro
Guest
Posts: n/a
Im going to have to tow the car to a shop now, no other option.
But what is the best way to tow this car? It doesnt seem like there is anything underneath in front to tie to.
Looks like I have a bad ECM. The whole car just goes haywire in everyway when trying to drive it (it doesnt even stay running now).
Old Jan 18, 2004 | 10:50 AM
Stephen 87 IROC's Avatar
Call a flat deck tow truck.
Before I bought my car trailer I used to tow the car to the track. I fabricated some tow bar mounts through the fog light holes. It wasn't pretty but it worked.
There is no easy way to simply just hook a chain or rope onto a third gen and tow it.
Old Jan 18, 2004 | 11:09 AM
Pro
Guest
Posts: n/a
What should something like this cost?
Old Jan 18, 2004 | 11:54 AM
krazzycowgirl's Avatar
If you are towing on something like a tow dollie the car should be backwards. The Rear tires on the Dollie.
But I agree on a flat bed would be lots better.
Old Jan 18, 2004 | 12:04 PM
TheGreatJ's Avatar
A rollback wrecker (or "flatbed") is the only way to go with a 3rd gen. A wheel lift wrecker or tow dolly is gonna angle the car too much and probably scrape the ground effects and tailpipes right off...not to mention the fact that posi rears dont like being towed. I also wouldn't put the car on a dolly backwards....the front ground effect is low enough as it is and if the front wheels aren't perfectly straight and locked in place the car will be all over the road.
Old Jan 18, 2004 | 12:12 PM
irocznformula's Avatar
the cost of a used ecm would be cheaper than the towing bill. if you really think thats the problem why not atleast try changing that out with another? they are very easy to change and can be done in any parking lot with any 5 dollar tool kit. they interchange with a bunch of gm vehicles so any salvage yard should have one on the shelf. just make sure to put your chip in the new ecm.
if you dont feel like messing with it id have to go for the flatbed as well.
Old Jan 18, 2004 | 12:29 PM
Pro
Guest
Posts: n/a
Haha I really dont feel like jacking with it anymore.
Plus I have already called around at every salvage yard in town and they have NO L98 parts. Im not even joking, they dont have jack.
Old Jan 18, 2004 | 02:01 PM
Dave89IROC's Avatar
a reman ECM is about $85-110 from autozone
Old Jan 18, 2004 | 02:10 PM
Black6SpdTA's Avatar
I'd look around for a new ECM.
www.ThirdGenResource.com
www.HawksThirdGenParts.com
www.EBayMotors.com
www.ThirdGen.org
www.CamaroZ28.com
All the sites I can think of to look for one.
But if you insist on towing it--We rented a U-Haul trailer for the GTA. Worked great, up to speeds around 75. Cost ~$50 Pulled real nice.
-Corey
Old Jan 18, 2004 | 02:27 PM
Pro
Guest
Posts: n/a
www.EBayMotors.com
www.ThirdGen.org
www.CamaroZ28.com
-Corey
Yes Iv done this several times. Problem - car doesnt run. How to get it up the ramp. Need wench from tow truck.
Old Jan 18, 2004 | 02:46 PM
The GTA didn't run either Just took 3 guys and one steering it.
Old Jan 18, 2004 | 03:43 PM
aklim's Avatar
I thought it was the EPROM that was different and that the ECM itself was the same.
Old Jan 18, 2004 | 04:34 PM
yes each eprom is different for each engine and the ecm is shared with a bunch of other vehicles that gm made. i had to get one for my l98 and i think it came out of a cavalier, and only cost $35 bucks at a salvage yard. most yards can look up the crossreference on their computers. and even if theyve never had an l98 in their yard they will most likely have the right ecm.
Old Jan 18, 2004 | 06:03 PM
Pro
Guest
Posts: n/a
K sweet I just got off the phone with Autozone, told me they had one that was 60, and one was 70 (needed OEM num off it).
Old Jan 18, 2004 | 07:26 PM
92BLKL98's Avatar
Go to Thirdgen.org they have a chart that shows what cars got what ECMs. Anyone who thinks you need an L98 specific ECM does not know the system. The 7730 ECMs were common to many different GMs. Here's the link:
http://www.thirdgen.org/newdesign/te...erchange.shtml
