Mystery Vaccume lines
Old Jan 11, 2004 | 01:19 PM
LandryP's Avatar
You ever start a simple project and find so many other problems you wonder how the car evan ran in the first place. Well my 88 Camaro had no heat at all, the coolent just wasn't heating up so i decided to replace the thermostat, which requires removing the upper intake. which causes every plastic vaccume line to shatter then I noticed the coil wire's corroded badly, the inside of the distributer cap is full of rusty water and so on. But anyway here's my question as i was looking for the heater core bypass (my car dosn't seem to have one?) I noticed two vaccume lines coming out of the fire wall that havn't been hooked up to any thing in a long time, I assume there for the climate control I can't seem to find where they should go in the engine compartment, anyone know?
Old Jan 19, 2004 | 06:28 AM
jer's Avatar
jer
well im almost having the same problem but i know were they go one goes to the upper intake in the back the same place as the brake booster .........my problem is i broke the little plastic one and don't rember were they go .
Old Jan 19, 2004 | 06:37 AM
irocz2804's Avatar
if i was you i would get a chiltons or something similar so that you can see pictures and have it to refrence to also...
Old Jan 19, 2004 | 06:44 AM
jer's Avatar
jer
okay were can i buy one from the parts store only has the haines books
KYWes
Jun 14, 2022 06:52 AM
pimpen1024
Aug 19, 2015 08:36 PM
Fastbird93
Jul 11, 2015 04:37 PM
Boss002
Jul 9, 2015 03:33 PM
colts0455
Jul 8, 2015 12:21 AM
