350 SLP TPI Headers on a 305 TPI???
Old Feb 2, 2004 | 04:12 PM
gchu's Avatar
I wanted to upgrade the exhaust on my 88 305 TPI Auto - will headers from an 89 350 TPI fit? I found a dual exhaust setup from a 350 TPI (SLP Headers with flowmaster cat back) for sale, but wanted to make sure it would fit - with fit meaning no special brackets or machining for clearance.
Anyone know?
Old Feb 2, 2004 | 04:28 PM
Blown350ZZ4's Avatar
The recomended header size for 350's are 1 3/4. For the 305's, the recomended header size is 1 5/8. I think this is why they differentiate between the 305's and the 350's. I am not positive though. I would say call SLP and ask.
Nick
Old Feb 2, 2004 | 09:55 PM
aklim's Avatar
Using the larger header for a smaller engine, unless it is blown or you have NOS, would mean that scavenging would be reduced because it would reduce exhaust charge velocity. simply put, don't.
Old Feb 4, 2004 | 02:29 PM
gchu's Avatar
Are you talking about the scavenging concerns with both of SLP's headers (the 1 5/8 and the 1 3/4) or just the 1 3/4?
I was planning on installing the SLP 1 5/8 Headers with the Y pipe for dual cats, use the stock dual cats and a flowmaster cat back. Would this actually hurt the performance of a 305 TPI then?
Old Feb 4, 2004 | 02:35 PM
Ray86IROC's Avatar
I believe they were speaking of the 1 3/4" inch versions, plenty of people run the 1 5/8s on both 350s and 305s. I have the Edelbrock TES 1 5/8s on both of my thirdgens, they definitely did not hurt the performance of the 305 in my IROC... Just find out which it is you're looking at and decide from there, I don't think you'd want to run the 1 3/4" versions on a 305...
Old Feb 4, 2004 | 03:33 PM
aklim's Avatar
1 5/8 is fine but if you run too large a header (1 3/4) you lose some scavenging which empties out the combustion chamber. So, for a 305, 1 5/8 is fine.
Old Feb 4, 2004 | 10:14 PM
97WS6SCharged's Avatar
I've always run 1 5/8" headers on my 350s. You would need a pretty stout engine to need a 1 3/4" header.
Old Feb 4, 2004 | 11:38 PM
aklim's Avatar
The one in the sig? I would go with the 1 3/4 for that, IMO. a 1 3/4 is fine for a modded 350 or larger, IMO
Old Feb 5, 2004 | 01:54 AM
Yeah, even the supercharged LT1 is running 1 5/8" headers at the moment. And the turbocharged 383 I'm building will probably run 1 5/8" primaries to help the PT76 turbo spool up as fast as possible for fun on the street.
Old Feb 5, 2004 | 01:28 PM
BigCasino87GTA's Avatar
From: Chillin' with Frank, Dino, Sammy and Pete at the Sands!
Very informative thread guys, switching headers on my 87 and was wondering about which would size/sizes would suit my needs best.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
STR FTR 1
Feb 10, 2015 10:36 PM
CaRParts102
Dec 6, 2014 08:45 AM
Carguy00
Aug 6, 2002 10:25 PM
