350 TPI Fuel Injectors
If you change your 305 for a 350, you can add 3-5 psi of fuel pressure and use your 305 injectors. But, the 305 injectors are only good for about 350 hp, the 350 injectors are good for about 440 hp. So, if it is an "extreme" 350, you may need to consider an upgrade.
Have fun.
Have fun.
Jul 4, 2005 05:00 PM
