What Sized Throttle Body would be best for my 305?
Old Jan 17, 2004 | 06:07 PM
94LT1Maro's Avatar
I've decided for budget reasons just to keep my current engine and slowly build it up. One of my first planned mods was a new throttle body. What size should I get? And how much power can I expect from one? And last but not least which brand should I go with? I'm looking at Edelbrock but if there's a better product out there i'll look at it. Thanks guys.
Old Jan 17, 2004 | 06:46 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
A 305 or a 350? TBI or TPI? Your sig says TBI. Either way, unless you're running a blower on your 305, the stock throttle body is fine for both types of induction.
Old Jan 18, 2004 | 12:40 AM
94LT1Maro's Avatar
305 TBI........and i'm not looking at Forced Induction i'm going N/A. So seriously how big do I need to go. I've decided on Edelbrock and when I get a definite size i'll order it and go from there. Thanks guys I really appreciate it.
Old Jan 18, 2004 | 12:11 PM
axoid's Avatar
The stock TBI is capable of up to ~250 crank hp. I have 213 rwhp out of mine, but under full throttle a vaccum begins to develope above 4000 RPM. I figure that this is because that the engine wants more air but the throttle body has hit it's limit.
Old Jan 18, 2004 | 01:22 PM
krazzycowgirl's Avatar
If you are looking for a throttle body Check out BBks you can find them VIA summit racing
Old Jan 18, 2004 | 02:11 PM
NOMAD's Avatar
Cool
BBK doesn't make a TBI throttle body.
Stick with your current one and get a better flowing intake. The current stock set up will feed you well enough air and fuel for your 305. Get the better flowing intake or headers and you'll be much happier with the results.
-Shannon
Old Jan 18, 2004 | 02:56 PM
94LT1Maro's Avatar
Which Intake should I go with?
Old Jan 18, 2004 | 04:01 PM
Kevin91Z's Avatar
Edelbrock makes a nice TBI intake manifold.
Once you step up to a 350, there are a couple manufacturers out there who make the 650 cfm throttle body for TBI. I cant think of their names right now but I'm sure some TBI guys will chime in. For a 305, the stock throttle body is fine.
Old Jan 18, 2004 | 05:44 PM
axoid's Avatar
The stock TBI's bores are 1 11/16 inch diamiter. Holley makes a TBI with 2" bores but the injectors suck. GM 454 tbi's are also have 2" bores. There are others that can port the stock TBI, but I cann't remeber those at the moment.
Old Jan 19, 2004 | 01:37 AM
94LT1Maro's Avatar
I wanna keep my 305 even though it's been acting up recently. It'll start right up sometimes but others it'll fire then die and when I fire it up again I have to rev it to keep it running. Sounds to me like a Starter Problem. And I really hope that's all it is maybe y'all could help me out with that as well. Another theory of mine is that the fuel system just needs an extensive cleaning. Maybe my injectors are clogged who knows but I guess i'll have to play with it and find out.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Jul 4, 2005 05:00 PM
