Do SLP headers # 3001C have....
Old Jan 27, 2004 | 08:50 AM
91RSLT1's Avatar
These are the 1 3/4" coated headers w/ AIR 1cat. I was woundering if these came with two o'2 bungs, and if they cam with their own y-pipe. I need two provisions for both oxygen sensors of the LT1. If they do not then I will just get the non coated, add the bung, and then have them coated. I just don't want to add the bung and destroy/discolor the coating. Thanks.
Old Jan 27, 2004 | 11:21 AM
Blown350ZZ4's Avatar
I bought the ceramic coated 1 3/4 inch headers without the AIR inlets. I only had 1 fitting for an 02 censor on the driver's side header.
Your best bet is to give them a call and check it out to make sure.
Nick
Old Jan 27, 2004 | 01:19 PM
aklim's Avatar
Single bung on the driver side. Get uncoated ones and weld what you want where you want and then you can coat them
Old Jan 27, 2004 | 02:11 PM
91RSLT1's Avatar
So do they come with their own y-pipe? Any one have any pictures? I guess I will go with the 3001, the non-coated ones. Any one know roughly how much it would be to have them coated? Who should I have coat them?
Old Jan 27, 2004 | 02:35 PM
they should come with a Y Pipe but you are also going to need a few more things. You need their gasket set and a small elbow for between your Y pipe and your cat(s). I think both of those are about an extra 40 - 50 bucks.
Nick
Old Jan 27, 2004 | 04:45 PM
91RSLT1's Avatar
Could I just get the coated one and then add the additional O2 sensor in the y-pipe on the passenger side?
Old Jan 27, 2004 | 10:02 PM
aklim's Avatar
It depends on how fussy you are. You could get the coated ones, drill a hole and weld a bung there. It probably has to be welded so it might scar up the finish a little but that is an alternative.
Pig Pen
Parts Wanted
Apr 30, 2015 08:41 AM
BLUETOPTA
30
Sep 18, 2002 12:22 AM
jim88iroc305
Aug 13, 2002 09:24 PM
