how do u disable speed limiter
Old Jan 20, 2004 | 11:24 PM
SSnthe10s's Avatar
i have a 92 birds with a 305 and TBI unit. i was wonderign what i have to do, to diable my speed limiter.
any help would be sweet
thanks
Old Jan 21, 2004 | 12:00 AM
Dave89IROC's Avatar
either disconnect the speed sensor wires(will lose speedo and set a code), or get it changed in the chip
Old Jan 21, 2004 | 12:34 AM
bmillington's Avatar
Maybe stuiped question but, 3rd gen's has speed limiters?
Old Jan 21, 2004 | 01:01 AM
SSnthe10s's Avatar
ya im pretty sure
Old Jan 21, 2004 | 01:46 AM
Zepher's Avatar
TBI cars and V6 cars have limiters in them. I haven't seen a TPI car with a limiter set low enought to slow the car.
Here is a picture of my tuning software with teh speed limiter set to 255,
Old Jan 21, 2004 | 09:28 AM
SSnthe10s's Avatar
LOL 255 i need that Hax0r!
w00t w00t
Old Jan 21, 2004 | 10:10 AM
aklim's Avatar
You cut the VSS and you also lose cruise control and set a code. Not sure if it does affect the way the ECM does the fuel mix tho. Also I believe 3rd gen TPIs came with speed limiters if the tires were not Z rated.
Old Jan 21, 2004 | 03:52 PM
irocz2804's Avatar
my 87 iroc had a speed limiter at 130 but when i got the new chip it disabled it
Old Jan 21, 2004 | 04:10 PM
SSnthe10s's Avatar
where do i get a chip for my car. and how much are they??
Old Jan 21, 2004 | 04:53 PM
firebirdjosh's Avatar
I honestly believe my car wopuld fall apart at 130mph if it can go that fast. At 85ish it starts shaking violently.
Old Jan 21, 2004 | 04:54 PM
Dave89IROC's Avatar
how fast do you plan on going? AFAIK, the TBI cars had the speed limiter at 110 MPH
Old Jan 21, 2004 | 04:55 PM
Ville H. Valo's Avatar
www.thunderracing.com
Section
1982-1992 F-Body
Subsection
Computer
That is the cheapest i found....
-Ville H. Valo
Old Jan 21, 2004 | 04:57 PM
firebirdjosh I honestly believe my car wopuld fall apart at 130mph if it can go that fast. At 85ish it starts shaking violently.
I used to have a 1989 Camaro RS w/ a 2.8, it would shake at 85mph but would stop around 100mph. try balanceing the tires...
-Ville H. Valo
Old Jan 21, 2004 | 05:16 PM
Zepher's Avatar
I can burn one for you for $50, if I can find another chip lying around. The blank chips used in the TBI cars got quite expesive locally, $28 just for a blank chip.
For comparison, the Flash Chips I use in the TPI cars are larger with more memory and I can get those for $6 a pop.
Old Jan 21, 2004 | 05:40 PM
Can you burn me one that would be the same as a Hypertech, for a 1992 TPI CAmaro Z28 5.0?
