iroc-z tpi on a 350
Old Jan 13, 2004 | 04:21 PM
z28 84chev's Avatar
iroc-z tpi on a 350
is it possible to take a an iroc-z 350 tpi and put it on a 350
Old Jan 13, 2004 | 04:40 PM
chevyman502bb's Avatar
if the 350 is post 87 and doesnt have vortech heads it should work........but check for a 2nd opinion, i could be/usualy am wrong
Old Jan 13, 2004 | 06:58 PM
Black6SpdTA's Avatar
The setup will fit on any SBC without special bolt pattern heads (i.e. Vortecs, Fastburns, etc). 87+ is centerbolt valve covers/hydraulic roller cam, I *think.* In that case, it wouldn't affect the intake setup.
-Corey
Old Jan 13, 2004 | 09:58 PM
RIPPIN TO THE RESCUE!
lmao.....j/p with ya......anyways, theres the answer to ur question
Old Jan 14, 2004 | 01:25 AM
BOZS89IROC's Avatar
-Corey
Exactly right, although the roller cam shouldn't be much of a problem. You can (and should) by a kit to upgrade to a roller cam. Other things to look for: knock sensor (do you have one) and O2 sensor. What kind of tranny do you have? You'll need a host of sensors, wire harness, ECM, electric fuel pump, intake setup, etc.
Old Jan 14, 2004 | 02:43 PM
z28 84chev's Avatar
yeah i knew i would have to put a fuel pump and some computer stuff which i really wanted to stay away form and such even though i know alot about it i like to stay low tech but it's got a th400r tranny i think i can't rember off hand sorry i'll get all the slips cause it has a completly diffrent setup and things will post soon
Old Jan 14, 2004 | 04:46 PM
Dave89IROC's Avatar
It will work on 87 up center bolt heads(except vortec) no problems
it will work on pre 86 perimiter bolt heads by just ovaling out(not much) the center bolt holes in the intake, and using washers on the bolts
Old Jan 14, 2004 | 05:09 PM
formularpm's Avatar
What does the engine have for induction now? If you go from carb to TPI, be forewarned that you may lose power; especially from 4000 rpm to redline. The other aspects of EFI make it a worthwhile swap, but you may want to consider a different style intake than TPI, something affordable like an HSR or converted LT1 intake. This depends heavily on your current combonation of course. Just want you to be aware of other options.
www.lt1intake.com
www.stealthram.com
G-BODYT56
Jan 14, 2022 11:14 PM
HAWG
Sep 25, 2015 11:41 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
