Tranny compatibility question
Old Jan 18, 2004 | 10:45 PM
splinter_cell's Avatar
I have a 700R4 in my 84 Z right now. I will probably be getting a 91RS that has a shot tranny. I can swap the tranny in my 84Z into the 91 RS without any problems right?
Old Jan 18, 2004 | 11:11 PM
Black6SpdTA's Avatar
Both are 700R4's? I am 99% sure they'll interchange.
Speedometer: In 1990, Camaros got a VSS equiped electical speedometer. 1984 still had mechanical. I don't know what you'd do about that. I geuss you could just put a VSS sender in the '84 tranny.
-Corey
Old Jan 18, 2004 | 11:15 PM
Im pretty sure its a 700R4, unless the guy swaped it out for something else.
The 91 is complete, it just does not have the tranny. So I dont have to worry about the speedometer right
Mike
Old Jan 18, 2004 | 11:19 PM
trackbird's Avatar
The 91 will have an electronic sender for speedometer hook up. And, as I remember, they changed to a 4000 pulse per mile sender in 1989 or 1990 (check me on that). So, you may need a sender. The input shaft changed at 1984 1/2 from 27 to 30 splines for the torque convertor, but, if you use your converter, it will all fit.
Old Jan 18, 2004 | 11:23 PM
Ok, any idea how much a sender will cost? I will probably use my converter to make the swap as simple as possible. Thanks.
Old Jan 18, 2004 | 11:54 PM
aklim's Avatar
I'm going to say under a hundred because it was years ago when I replaced my VSS
Sergio
Jan 27, 2016 04:27 PM
rwferguson43026
Feb 6, 2015 10:06 AM
importkiller94
Jan 17, 2015 09:03 PM
nballisru
Dec 14, 2014 05:01 PM
mattszm6
Dec 14, 2014 07:09 AM
