carb & intake swap
Old Jan 16, 2004 | 10:58 AM
83' Z28 CAMARO's Avatar
carb & intake swap
my 83 Z has a crossfire 305, i want to put an edelbrock performer carb and intake on it, is it an easy swap? besides the carb & intake what other parts will i need? and is this a good swap? will i really gain anything on performance? thanks for any help you can give!
Old Jan 16, 2004 | 11:22 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
You need, a fuel pressure regulator cause the FI fuel pump is gonna spit out more fuel pressure than the carb will like. And you need a pre 80 distributor so it isnt computer controlled
Old Jan 16, 2004 | 01:15 PM
TheGreatJ's Avatar
That about covers it. You'll probably notice a nice gain because the CFI engines are notorious for needing constant attention and if it hasn't been carefully set up and maintained you're losing a lot of power.
Old Jan 16, 2004 | 07:45 PM
Rice Killer87's Avatar
check out the Mallary adjustable fuel pressure regulator. ive got 1 on my car to take the F.I. fuel pump down to 5 psi and it does a great job. it has 3 ports around it,and 1 on the bottom...u can do like i did and plug 1 of them,use 1 for getting the fuel to the carb,and the 3rd to put a fuel pressure gauge in. send me a PM (private message) if u want,and ill take a picture and send it to u. the thing runs about $75-80 but its worth it.
Old Jan 16, 2004 | 11:27 PM
sounds pretty simple, thanks a lot!
dfarr67
Apr 10, 2015 07:44 PM
InfernalVortex
Jan 17, 2015 09:35 AM
markaubuchon
Jan 14, 2015 01:48 AM
