doesn't warm up
Old Jan 28, 2004 | 05:48 PM
Max 93's Avatar
doesn't warm up
The car is a 91 Camaro six cyl. It doesn't warm up. You can run the car for an hour and it might get up to 140*. They just put in a new thermostat and that didn't help. Any ideas?
Old Jan 28, 2004 | 05:53 PM
Rice Killer87's Avatar
u sure teh gauge is right? start the car up and let it run for like 10 minutes and pop the hood and put ur hand on the upper radiatior hose and it should be pretty warm. if it is,then it might just be the gauge sending unit,but if its not...then theres problems elsewhere...just something to check.
Old Jan 28, 2004 | 05:56 PM
Max 93's Avatar
it also have very little heat. so I don't think the gauge is reaging low.
Old Jan 28, 2004 | 08:29 PM
Irocvette355's Avatar
Sounds like a stuck open thermostat to me
Old Jan 28, 2004 | 09:08 PM
Max 93's Avatar
just put a new one in and it didn't help.
Old Jan 28, 2004 | 09:14 PM
krazzycowgirl's Avatar
Your fan running before it suppost to?
Old Jan 28, 2004 | 10:03 PM
Dave89IROC's Avatar
you sure they put in a high temp(195) thermo?
this is a classic case of stuck open/low temp open thermostat
Old Jan 28, 2004 | 11:52 PM
trackbird's Avatar
No heat can mean a bad heater core (clogged). Now, you would have to have a bad gauge or sending unit and a clogged heater core (both) to get no heat and a low temp reading on a motor that has enough coolant and a functioning thermostat in it. This is not likley, but anything is possible on a vehicle, and the older the car, the more possible it becomes.
I'd check the top heater hose as suggested and see if it is getting warm. If the hose is getting warm (hot) and then I'd suspect there could be a case made for the above scenario, but I'd be suprised. Or, as suggested, it has a 165 thermostat in it.
Is it full of coolant? If it is not full, you may not have enough water to circulate and that could cause a loss of heat (or nearly no heat, but usually a high reading on the gauge).
Odd....keep us posted.
Old Jan 29, 2004 | 12:38 AM
aklim's Avatar
I'm assuming there is plenty of coolant and did you check the thermostat for opening temp B4 you installed it? Also, did you take a temp reading of the head where the coolant sensor (between #1 - #3 plug) so you know what it is? You sure your heater valve is operating?
Old Jan 29, 2004 | 04:21 AM
greezemonkey's Avatar
It sounds like you`d be a canadite for a hillbilly t-stat! How cold is it up there in WI? 10 -20 degrees?LOL!! Try placing a cut piece of sheet aluminum or galvanized like.18 gauge in front of the radiator......Now dont block off the whole thing just 75% of it. Ever see school buses with the leather bra over the grill?
Old Jan 29, 2004 | 07:17 AM
Max 93's Avatar
thanks for the replies. The car is my cousins car so I will pass this info on to him. By the way, greezemonkey, it is -6 this morning
Old Jan 29, 2004 | 11:47 AM
trackbird's Avatar
-6?
I'm leaving for Daytona in 2 hrs.....
Ahhh....warmth....
Old Jan 29, 2004 | 02:10 PM
aklim's Avatar
Originally posted by trackbird
-6?
Ahhh....warmth....
Fork you with a large broom handle.
Old Jan 31, 2004 | 09:14 AM
LandryP's Avatar
I had the exact same problem with my 6 cyl camaro. Replaced the thermostat with no change. The new england cold finaly forced me to do something about it. I replaced the thermostat again with a heavy duty 190 deg one and now I've got heat. The heavy duty stat was like 2 dollars more that the standard one it had a much bigger spring and thicker housing. Also my my fan was never shutting off so I unpluged prior to replacing the thermostat and it had no effect of the engine temp.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
ducttape1975
Jul 10, 2015 06:29 PM
