i have a ? about abs hookn up on a 12 bolt!!
Old Jul 11, 2005 | 12:12 AM
4SFEDZ's Avatar
ok im buying a 12 bolt thats in a 97 camaro, does my 94 camaro have the same abs setup, plugs, ect, as the 97. he said it will bolt right in but he wasnt sure about the abs if the abs would hook right up? so i guess my ? is, is the abs in my 94 the same than in the 97?
Old Jul 11, 2005 | 05:54 PM
Z28Nut's Avatar
Re: i have a ? about abs hookn up on a 12 bolt!!
If you have a wire that goes to a sensor on top of the diff housing you have 3-channel ABS, if the rear has sensors at each wheel it's 4-channel. Check to see if the '97 is the same as yours. I think if the car has traction control, it'll be 4-channel. Not sure so don't shoot me if I'm wrong . I have a '94 w/out trac control and mine is 3-channel.
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
Black Sunshine/ 00SS
Sep 3, 2002 08:56 PM
Aug 31, 2002 02:26 PM
