M6 x-member, TH-400...spacer? VSS sensor?
Old Jul 20, 2005 | 11:13 AM
CANTONRACER's Avatar
I recently put in a TH-400 using a M6 x-member & an Energy Suspension transmission mount. It bolts up fine, but I have heard that you still need a spacer. Is this correct and if so, how tall is the spacer?
Also, does the 4L80E use a VSS that can be used with my TH-400? Is it just as simple as popping the tailshaft out, put in the reluctor ring and put it back together?
If I can use the VSS from the 4L80E, what would be the GM part # for the VSS and reluctor ring?
Old Jul 20, 2005 | 11:55 AM
Re: M6 x-member, TH-400...spacer? VSS sensor?
I found a picture on LJ's site and the part #'s for the VSS sensor and reluctor ring there.
MDZ28
Sep 7, 2015 09:16 PM
FredM
Aug 14, 2015 01:49 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
