how much power can a stock tranny and rear end take?
i have a 97 lt1 camaro with the 6sp manual and i was wondering how much hp and torque the tranny and rear end can handle without any modification
also what can i do to strengthen both of them if im planning on 500hp or more
Re: how much power can a stock tranny and rear end take?
I'd say you will have to o with a much beefier clutch/flexplate, and definetly upgrade the rear to a 9" or 12 bolt. Manual cars chew that 10 bolt up way to easily.
the t56 is rated at 450lbs ft of torque from the factory...they can handle more if need be.
but yeah the clutch and rear will blow way before the trans
Originally Posted by shmo925
thanks guys
what 12 bolt fits in a 97 camaro. where can i pick one up
You can find it Here (click)
I have less than 400hp at the crank and I've tore up my 10-bolt 3 times. With a rather hard shifting auto
I pick up my DriveTrainSpecialists 12-bolt tomorrow. DTS, Moser and Strange all make 12-bolts to fit 4th gens.
stock t56 can take a lot. the 10 bolt will live if you are easy on it off the line. 1.9-2.0 60s' and no wheel hop will give you decent rear end life.
oldschool
Feb 9, 2016 09:21 PM
