Looking for gear brand suggestions
Old Jul 1, 2005 | 06:40 PM
BlackM6Z28's Avatar
The rear is whining in my 95 Z and I've been told its the pinion bearings. I figured now is a good time to swap out the gears and go 3.73 (no 4.10's, this is street driven more than it's raced!). I've read that Richmond gears tend to be noisy. What about SLP gear set? Or should I stick with good ole' GM genuine parts. Thx folks.
Old Jul 1, 2005 | 10:37 PM
roguedriver's Avatar
Re: Looking for gear brand suggestions
If you hate whine, don't go the Richmond route. I had 2 sets in my 10 bolt. 3.73's and 4.10's and both were noisy. I finally went with 4.10 Motive gears and they were pretty quiet. Had a slight whine, but almost not even noticable. I would consider 4.10's though since you have a 6spd. Even though it's a street car, 4.10's in the 6's are very streetable. 3.73's aren't as much of a step up from your 3.42. If you dead set against 4.10's, i'd stick with the quiet stock 3.42's if your worried about whine and just go through the rear and replace all the bearings and redo a setup.
Ken R.
Old Jul 1, 2005 | 10:52 PM
Bow94z's Avatar
agreed, i just got my 4:11's in the car today...boy do they wake the car up! i wouldnt even consider 3:73s on a M6...I drive my car everyday, and its not as harsh as you think it would be...Go with the 4:10's
Old Jul 1, 2005 | 10:57 PM
CamaroSS30thAnn's Avatar
motive
Old Jul 4, 2005 | 06:35 AM
BlackM6Z28's Avatar
What about fears of breaking the stock rearend? Like I said, this is for the most part a daily driver but I have taken it to the track on occassion (but I ain't doing any 5000-6000 RPM launches neither). I'm running Nittos on the rear and from all the reading I've been doing, I should be safe.
Old Jul 4, 2005 | 11:52 AM
92LT1RS's Avatar
I just put Motive 4.11 gears in mine and they make no more noise than stock. Installed them myself as well.
Old Jul 5, 2005 | 05:42 AM
Pro Built Automatics's Avatar
Go to http://www.justdifferentials.com/sto...cat=381&page=1 this should give you what you need. Let me know if I can be of help?
Old Jul 5, 2005 | 07:05 AM
rskrause's Avatar
Moderator
For a street gear, the GM gears are a great choice.
Rich
Old Jul 7, 2005 | 09:49 PM
Blownpickl's Avatar
I have a 9" available that came out of a Gen 3 It would bolt up in minutes sway bar and all. Blownpickl@aol.com $750 housing and axles
chevy95z28
Jun 22, 2015 09:28 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
Omega9
Aug 14, 2002 10:59 PM
