Will a lose trans mount cause a vibration at high speeds?
Old Jul 12, 2005 | 11:37 AM
93transam1234's Avatar
After my trans install i noticed a moderate vibration from 55- 80 mph not related to RPM just speed.
I checked my poly trans mount and it has about 1/4-1/2 inch play in it.
Old Jul 12, 2005 | 12:44 PM
Prince's Avatar
Re: Will a lose trans mount cause a vibration at high speeds?
Sounds like you installed the driveshaft 180* out of phase. The DS is balanced with the yoke and needs to be re-installed the same way it was removed.
I actually just went through the same thing after pulling my trans. I had a harmonic vibration at the same speeds.
To fix, just unbolt the DS, rotate 180* and bolt it back up. That should take care of it.
Dave
Old Jul 12, 2005 | 01:18 PM
That was the first thing i did, and it helped alot with the vibration, but it still shakes the change around in my cup holder at over 55 mph.
Old Jul 12, 2005 | 05:30 PM
Bow94z's Avatar
well dont poly trans mounts vibrate anyways? I went with a LS1 trans mount and i am very happy with the mount. Are you sure the nut for the trans mount is tight?
Old Jul 12, 2005 | 08:55 PM
even tho the nut is tight, thrir is still a lil play
Old Jul 12, 2005 | 09:50 PM
Z28Nut's Avatar
The mount has play between the crossmember or tranny and mount or is it just play in the bushing itself? The poly bushing will flex a little but there should be no play between either the crossmember and mount or transmission and mount. The nut could be crossthreaded and just feel tight.
Old Jul 13, 2005 | 04:00 PM
the space is between the mount and the crossmember, as i looked at it better it is actulay betwen the bolt and the cross member (kinda like its not screwed all the way in) It is not cross threaded. I am going to just get some washers i guess.
NOW does anyone know if this sounds like it is the cause of my vibration?
Old Jul 13, 2005 | 04:52 PM
Z28Nut's Avatar
Yeah, it should take care of a lot of it but poly mounts are more rigid than the stock rubber mounts so it is going to pass on more vibration than stock.
Old Jul 13, 2005 | 05:09 PM
ABA383's Avatar
I had the same problem with my Spohn trans mount bolt bottoming out before it was tight. It came with a stud, so I ditched the bolt and used the stud and nut approach...Plenty tight, no vibration...
--Alan
Old Jul 13, 2005 | 07:06 PM
--Alan
did it have a vibration befor u used the stud? or did u not even drive it?
Old Jul 13, 2005 | 07:24 PM
ABA383's Avatar
I didn't drive it, but I would think that it would cause all kinds of vibration, especially under load when the trans tries to twist on the mount. I would either do the stud method or just get a shorter grade 8 bolt.
--Alan
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mattszm6
Dec 14, 2014 07:09 AM
siguy
Nov 27, 2014 10:07 AM
x7x7
Aug 15, 2002 06:49 PM
