Installing 12-bolt, few questions.
I just got done taking the old axle out and broke a few bolts during the process. Anybody know where I can buy a complete bolt kit for the rear end? The metric bolts seem to be hard to find, none of the local stores carry anything close. Also, anybody have a website that lists the torque specs for everything I just took apart(I probably should have checked into this before I started).
Re: Installing 12-bolt, few questions.
i've never found metric 10.9 bolts anywhere, i changed all the bolts in my suspension, i got grade 8 hardware from paracing, of course it wasnt a perfect fit, i had to drill the holes out just a little bit but the final fit is good
Ryan
I have a set of trailing arms and panhard bar with heims ends (spherical rod ends) for sale with all of the bolts you are looking for $150 Blownpickl@aol.com I also have the 9 inch ford from the car available if you haven't bought the 12 bolt yet. The axles (31 spline) and housing I need to get $750
