flywheel questions
Old Jul 4, 2005 | 12:11 AM
69vette's Avatar
flywheel questions
What flywheel would i have to run if i wanted to use a sbc w/ the lt1 t56. i know it will bolt up fine as far as the bellhousing but the flywheel would need to be different i would think to accomidate the 2 piece rear main seal design. I already havea mcleod street twin so i was planning on reusing it with a new flywheel that works properly. Also would you have to run the lt1 starter still? thanks
Old Jul 5, 2005 | 08:11 AM
95NateZ28's Avatar
Re: flywheel questions
To the top.
I need to know the same thing, the only problem is my engine is a 2 piece seal 383. What flywheel? Anyone?
Old Jul 5, 2005 | 06:30 PM
69vette's Avatar
you need the same one i need then for the 2 piece rear main seal. mcleod and centerfore make it..i just need to find time to call. i though someone on here would have done it before though
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Ringmaster72
Feb 25, 2015 03:15 PM
Newgmman
Feb 25, 2015 02:53 PM
HectorM52
Jan 30, 2015 11:08 PM
mattszm6
Dec 14, 2014 07:09 AM
